Anyone running a Yaffe stealth 3 tag frame on a rushmore wondering how it fits i read a few extra holes needed drilled mainly if it covers the old holes once mounted? I want to get rid of the towle bar and do some plasma rods with it.
Custom Dynamic makes one that is less expensive. $74 for the 2 pcs and Custom Dynamic LED's so far are a nice quality piece.
Do you have a part number, or any more info about this? Sounds like a deal. I want to do the same thing as the OP, but hate the circle frame of the Yaffe.
That is only a license plate frame, there is no way to mount it.
Originally Posted by Ultraboy105
This is for the bikes that have the plate above the light on the fender already. While I think you could make it work, you would need to drill more holes and either make another bracket, or weld some studs on it.
I just bought the kuryakyn frame made for the street glide/road glides. I'm going to cut the bracket off the top, and try to figure out a way to use the 2 holes in the fender to mount it.
