Putting apes on a '16 FLHX with ABS requiring upper brake line change from the master to the ABS module. Am aware of not turning on ignition when bleeding, etc. so as to not cycle the module. As the routing of the line to the module is as it is, you have to start there and install it and work your way up to the master cylinder. That said, for anyone that has done this, has there been any issues with installing the new dry line at the module and then up to the master cylinder, hooking it all up and then bleeding it out the calipers? Doing it this way would send all the air from the dry line through the module. I read someone on here had hooked the line up at the master cylinder and placed the other end of the line in a jar of brake fluid and pumped fluid through the line prior to hooking it up to the module. As stated, with the routing that would seem to be a PITA. What have others done? I told him he should have it put on the DT afterwards anyway for insurance, but I'm trying to get it as best as possible.
