Bleeding brakes how to?
Old May 8, 2013 | 12:05 AM
marvo75's Avatar
marvo75
Default Bleeding brakes how to?
Yes i know how to bleed brakes, been doin it 25 years BUT, i put new braided extended lines on and cant get the handle to pump up for anything! Tips advice? Is there a trick?
Old May 8, 2013 | 12:08 AM
mkguitar's Avatar
mkguitar
are your new brake lines TUV or DOT approved ?
some stainless lines are for 'display' use and do not work well as brakelines
if they are real brake lines than just keep at it.
I sometimes use a syringe to push fluid up from the calipers back to the master cylinder.
if you have ABS there are additional steps.
Mike
Old May 8, 2013 | 12:17 AM
marvo75's Avatar
marvo75
Yea they are DOT and new...wont pump up for chit!
Old May 8, 2013 | 01:36 AM
Eunoterpsia's Avatar
Eunoterpsia
If you open the brake system from the abs module back - meaning at the abs output line or at the caliper - then the brake system can be bled by normal actuation at the pedal, lever, or by suction at the caliper or forced induction at the master cylinder.
If you open the brake system before the abs module - meaning at the abs input line or at the master cylinder and air is introduced into the line - a diaphragm at the abs valve wont seal and as far as it was explained to me, the dealer uses digital technician to cycle the abs valves to purge any air.
At least it's how the took my phucking money - but it solved my problem.
Old May 8, 2013 | 05:18 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
You're likely fighting the air bubble in the line, it's rising about as fast as you're draining fluid out.
The messy but highly effective way to overcome this is to bleed at the handlebar connection.
Squeeze the lever, crack the fitting, listen to the "snap-crackle-pop" of air coming out. Close the fitting and release the lever. Repeat a few more times until the air quits coming out and you're getting fluid.
Old May 8, 2013 | 05:30 AM
ericl's Avatar
ericl
Borrow, vac pump from auto parts store
Old May 8, 2013 | 07:02 PM
marvo75's Avatar
marvo75
Got em, took another hour but i got em done.
Old May 8, 2013 | 07:34 PM
Notgrownup's Avatar
Notgrownup
Sometimes they can be a bitch....
Old May 8, 2013 | 07:58 PM
marvo75's Avatar
marvo75
This was one o them times lol but shes fixed now spent the day riding...apes are KILLER!
Old May 8, 2013 | 08:18 PM
Napalm Dog's Avatar
Napalm Dog
Not sure if you can do it with abs brakes. But when I had trouble I would put brake fluid in an old style pump oil can and get a small hose and clamp one end to the oil can and one end ro the bleeder, open the bleeder and pump it backwards from the bleeder to the master cylinder works great.
97badfatboy
Aug 8, 2023 10:45 AM
dwdagen
May 4, 2017 08:54 PM
tech7734
Apr 22, 2017 10:45 PM
Choopy
May 23, 2015 12:33 AM
moody31699
Dec 23, 2011 04:56 PM
