If so did you choose the Power Max Header or the True Dual Header and why ?
Appreciate it it. Bonus check coming up and am finally going to get the stage one. Have decided on the Rcxhaust and will be going black all the way back . . .
Power Max headers, 4" RCX Slip-ons with Rival Elipse tips, S&S Stealth A/C and V&H FP3.
For me, the sound was what I was looking for, and I've been happy with the performance gain. Search youtube for Power Max headers and you'll get hits with comparative dyno runs on RC headers/slip-ons vs others.
One downside I've experienced with my Power Max exhaust pipes, and friends have also experienced with both S&S and V&H headers is that the front cylinder exhaust pipe mounts/hangs lower than stock. In tight right hand turns, the heat shield scrapes before the floorboards. Mine don't routinely scrape, but if I dip hard in a slow speed right turn, or lean hard right in twisties, I scrape. I've looked closely at the mounting, and there is no opportunity to raise them. The stock headers aren't "stacked" the same and gain enough clearance to avoid scraping before the floorboards.
I am awaiting the 4.5 mufflers but am pairing with their NEW Tormentor head pipe! They are touting exceptional gains!! Once I get it installed and dynode I will post some results! Should be by May 21.
Seems EXACTLY like the S&S PowerTune dual header. Same exact hidden collector. Plus side to RCX, they use factory mounts.
Also, the PowerMax headers closely resemble the Rinehart Slimline....hmm.
Not much can change with head pipe design I suppose: remove CAT, decide on 2-1-2 or 2-2, install, tune, ride.
