2014 SGS bigger front tire size?
Old Jun 8, 2016 | 08:23 AM
tyrant33's Avatar
tyrant33
Default 2014 SGS bigger front tire size?
I was wondering if anyone has tried to go with a slightly larger size front tire for their SGS. Stock size is 130/60-19 and I would like to go with something that gives me a larger then the 60 profile, possibly a 140/70? Just looking for thoughts. Thanks
Old Jun 8, 2016 | 08:50 AM
RollaMo's Avatar
RollaMo
A 140/70-19 tire would be more than "slightly larger".
130/60-19 = approx. 25.14" OD
140/70-19 = approx. 26.72" OD
So, the 140 would be approx. 1.57" taller tire.
Not sure if it would fit or not.
Old Jun 8, 2016 | 08:56 AM
RollaMo's Avatar
RollaMo
Harley uses a higher profile on the Limited, but they uses a smaller diameter rim to accomplish that.
Limited: 130/80-17 = approx. 25.19" OD
This is only 0.05" taller than your factory Street Glide front tire.
Old Jun 8, 2016 | 09:54 AM
firefox23508's Avatar
firefox23508
Not pertinent to your post, but I never liked the switch to the larger rim and smaller profile tire years ago. I prefer the larger tires on the !6 inch rims. Obviously I'm in the minority. Lucky for me they still offer the laced wheel option on the Road King that still uses the 16.
Old Jun 8, 2016 | 09:59 PM
Fishrrman's Avatar
Fishrrman
You could probably put on the same rim/tire that the Road King uses, but then the front and rear wheels won't match -- unless you put -both- rims from the RK on ...
Old Jun 9, 2016 | 07:16 AM
Sierra977's Avatar
Sierra977
140/60/19 tire is 0.5 inch taller.
Here's a tire size comparison chart.
https://www.tacomaworld.com/tirecalc...0r19-140-60r19
Old Jun 9, 2016 | 07:20 AM
tyrant33's Avatar
tyrant33
Just not a big fan of the lower profile tire. I've already bent 1 rim on a pot hole that wasn't deep at all. Tire pressure was good! If I had a larger profile tire on it, this wouldn't of happened. But as I found out I don't have a very big selection of the stock tire size either. Commander 2's are at a limited quantity. Maybe a rim swap out will happen in the future. But for now it is what it is. I wish they would of stayed with a beefier tire then trying to give the bike a sportier look. I'd rather have function over style.
Old Jun 9, 2016 | 11:23 AM
firefox23508
I second that.
Old Jun 9, 2016 | 11:58 AM
RKC1965's Avatar
RKC1965
What's on the new Road Glide Ultras. Isn't it a deeper 19" tire. I was thinking I might go with one of these when mine wears out.
Old Jun 9, 2016 | 01:27 PM
tyrant33's Avatar
tyrant33
Tires, Front Specification BW 130/80B17 65H for the 16 RG Ultra per Harleys site
