software update
Old Aug 24, 2016 | 08:18 AM
  #41
MilesOfTexas's Avatar
MilesOfTexas
Originally Posted by Brewmany
Azerbaijan Map has been added to the ROW map database
YES!!!!!!!
Originally Posted by ChristoHD
Ok - what does this mean anyway?
Means the Russians can invade on Harley Rushmores now, lol.
  #42
BigMike17's Avatar
BigMike17
Appreciate the feedback from everyone...for those tech challenged with the thumb drive like me and don't know what root directory means...
Root directory = the main thumb drive file. No folders, nothing else.
It's a good thing I saw this thread - I had the software v. 1.18 etc on my bike. Never knew this was something I could do.
Once again, learned a lot!
Old Aug 24, 2016 | 08:26 AM
  #43
WG2011's Avatar
WG2011
Read the instructions, you don't plug the bike into laptop. Download the zip file, unzip and copy the iso file to a flash drive, turn bike to accessories, once radio displays plug in flash drive.
Originally Posted by heritageblue2013
I can't figure this update out. I plugged in my Heritage to my laptop and nothing happens???
Old Aug 24, 2016 | 08:31 AM
  #44
MilesOfTexas
Good job! Just FYI, you can have folders and files in your root directory and still be able to to perform the update. What is key is that the ISO for the update be in the root directory, not zipped and not in a folder. So when you plug your USB drive into your PC and open it, you see it without having to go into a folder to see it.
Also, if you have music and other stuff on the USB drive, be sure to either delete the ISO or move it to a folder, else every time you insert the USB drive into the bike it will try to update the software again.
Old Aug 24, 2016 | 08:37 AM
  #45
BigMike17's Avatar
BigMike17
Thanks for the tips!!
Old Aug 24, 2016 | 08:38 AM
  #46
MilesOfTexas
I think he was kidding. A Heritage doesn't have the infotainment system.
Old Aug 24, 2016 | 08:48 AM
  #47
tyrant33's Avatar
tyrant33
Originally Posted by brewmany
azerbaijan map has been added to the row map database
yes!!!!!!!
lol
Old Aug 24, 2016 | 09:07 AM
  #48
Brewmany's Avatar
Brewmany
Careful here. If you don't correctly do this upgrade, you risk having your bike go out of EPA specs. If that happens, the upgrade will instead zap your ECM and hold your bike hostage by not allowing it to start or run, and via your laptop will report your nefarious activity to the EPA, HD Corporate, and the Department of Homeland Security, (just for laughs). They will then send you a bill for $,9650.00, and will only send you the unlock code for your ECM after the check for $9650 clears.
You have been warned. Proceed with due caution
Old Aug 24, 2016 | 11:44 AM
  #49
Custardglide's Avatar
Custardglide
Originally Posted by Schurk
Thanks, but is'nt that thee 4.3 nav version? I need the CVO version, and it's still not showing any updates on the EU site I have bookmarked and have used since 2014????
Old Aug 24, 2016 | 12:07 PM
  #50
RollaMo's Avatar
RollaMo
