riser bushing install help
Old Jan 1, 2017 | 07:00 AM
bobbyjoes's Avatar
bobbyjoes
Default riser bushing install help
anyone got advice on changing these ,i got a manual ,but i cant find how you get to bolt head on the bottom, or am i overlooking it ,thanks
Old Jan 1, 2017 | 07:24 AM
Covert Olds's Avatar
Covert Olds
You'll need to rotate the front end left or right to gain access to them from underneath.
Old Jan 1, 2017 | 07:27 AM
Covert Olds
More than likely, you'll need longer bolts when replacing the bushings. They are 1/2"-13 and either 2.25" or 2.5".
Old Jan 1, 2017 | 07:44 AM
bobbyjoes's Avatar
bobbyjoes
well when i got the bike i had them put 14 wild1 apes on,now putting 16 vindikta on,not sure if they put poly bushings in,they were always sloppy and came loose,thanks so far for the help
Old Jan 1, 2017 | 09:41 AM
bobbyjoes's Avatar
bobbyjoes
they were rubber,thanks
jpistone
2014-2024 Touring Models
20
Apr 1, 2018 08:54 AM
yandeltx
Aug 12, 2011 06:19 AM
gtrplyr
Mar 4, 2010 12:00 AM
barflea101
Jan 25, 2010 11:25 AM
Iceman
Apr 8, 2006 02:51 AM
