What else?
Old Feb 8, 2017 | 10:08 PM
Rdcris's Avatar
Rdcris
Default What else?
I have a $500 HD gift card to spend.
I want to put some cams in.
What other parts will be needed to install?
Do I need any special tools?
Been looking at all of the suggestions for which cams, but don't find what extra items are needed.
The bike is a 15RG with 13000 miles.
I'm going to buy the V&H power duels, already have Monster Ovals, with a decat head pipe, and a FP3.
Thanks
Old Feb 9, 2017 | 04:15 AM
Steel Wheels's Avatar
Steel Wheels
If installing adjustable pushrods you'll save time over pulling rockers. Gaskets, the locking tool for the crank/cam gears, O rings for the pump, bolt set for the gears, an oil change should just about take care of it. You no longer need the tappet block tapered pins.
As for me, I usually retain the stock pushrods. Time isn't an issue so pulling rockers is no bid deal. Actually, that would be a good time to go ahead and install a set of the Rockout lockers from John. Great guy who'll support you all the way. Even if the top end is quiet now it may not stay that way, so why not if you're already there.
Last edited by Steel Wheels; Feb 9, 2017 at 04:17 AM. Reason: Dam spell check grrr...
Old Feb 9, 2017 | 06:22 AM
ROCKOUT Rocker Products
Sponsor
Thanks brother
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Feb 9, 2017 | 06:58 AM
Rdcris's Avatar
Rdcris
Actually I just bought the RockOuts kit, and I will be replacing the seal for that goes to the A/C. I think thats why I'm consuming oil, found oil in the breather.
So I can reuse the stock push rods.
ZACKP
Engine Mechanical Topics
Sep 5, 2014 10:35 AM
Old Gunny
Exhaust System Topics
21
May 16, 2012 06:51 AM
91lowlyf
Apr 8, 2011 05:15 PM
wrustywrench
Feb 17, 2008 09:29 AM
dawg
Sep 26, 2006 05:23 PM
