How many way points
So how, without preriding, can you be sure you have enough waypoints on a route to make it go exactly where you want it to go?
I think I remember that you can have up to 99 waypoints in a route, but my question is how do you know the number that you must have to make it go where you want?
For example, I have a 386 mile ride with a start and end and 14 way points in between. I looked at a friend's ride, and his was only 45 miles long, but he had 28 waypoints, twice as many as me.
Still looking for the answer.
It all comes down to what roads you are traveling.
Think of it like this: Your GPS will import your starting point, ending point and any way points in between.
From there, the GPS will calculate your route to hit all of those points based on its own internal mapping algorithms (which includes your preference settings on scenic, longest, shortest, etc).
All GPS units work this way, so this isn't anything unique to HD.
As mentioned above, put in a few local rides around your area making several turns (even just hour long rides will work).
This will give you an idea and experience in how to create routes.
If there are multiple roads to take to get you from your starting point to your next way point, then you might need to add another one (to force the GPS to take the road you want).
If there is only one road or way to get there, you will need less waypoints, because all GPS's will take the same road.
Most GPS units have preference settings like shortest, fastest, avoid toll roads, etc.
The HD unit has these also, but adds scenic or twisty that I haven't seen on other units.
These preferences come into play when traveling from one way point to the next, so take that into account.
It just takes some practice and you'll get the hang of it.
https://www.hdforums.com/forum/new-r...els-177-5.html
Website: https://www.motogoloco.com/map/
