decatted head pipe smell
Old May 9, 2017 | 11:44 AM
digdug's Avatar
digdug
Default decatted head pipe smell
I'm getting a weird smell after I had my decatted head pipe installed. Kind of a burning plastic/electrical smell. Everything looks like it's installed correctly and it is not an exhaust leak. Maybe residue from the cat removal or the welding?
Any thoughts would be appreciated....thanks! Got it on ebay from "hd headers"
Old May 9, 2017 | 04:35 PM
chopper_man's Avatar
chopper_man
Double/triple check the o2 sensors and make sure they are not hitting the pipes.
Old May 9, 2017 | 08:27 PM
digdug's Avatar
digdug
I will do that.....thanks
Old May 10, 2017 | 06:58 AM
1HD1C's Avatar
1HD1C
I think they toss a coat of high heat paint on them probably what you are smelling burning off
Old May 10, 2017 | 02:39 PM
Uberjason's Avatar
Uberjason
Heat paint or anti-seize (from O2 sensors) burning off.
Old May 10, 2017 | 04:14 PM
chopper_man
My pipes from HD Headers were not painted, just a nice clean weld from where they removed the cat. I also used never-seize on the upper threads, no smell from that.
Old May 11, 2017 | 12:42 PM
daveblank's Avatar
daveblank
It's the welding. It will go away after a few days of riding.
Old Jul 29, 2017 | 09:25 AM
vspkent's Avatar
vspkent
That is the smell of non catalyzed exhaust gases. All non catalyzed engine way back in the day smelled similar.
Kent
Old Jul 29, 2017 | 01:11 PM
sirrat007's Avatar
sirrat007
Kent
No they didn't.....and when I drilled my cat it it didn't smell any different than before...but the exhaust heat sure got less
Old Jul 29, 2017 | 09:44 PM
rv7garage's Avatar
rv7garage
Just stop smelling the pipe. Problem solved
