another primary chain tensioner thread
Old May 17, 2017 | 12:10 PM
Wisenheimer16's Avatar
Wisenheimer16
Default another primary chain tensioner thread
The more I read about the tensioner the more confused I get. Is the auto adjuster really that bad? They have been using it for 10 years. How many of you guys have had no issues? Sometimes I wonder if the hype on this and other stuff is just to make money, although I am convinced the compensator is junk....more confusion. (16 ultra btw)
Old May 17, 2017 | 12:20 PM
WarHorse15's Avatar
WarHorse15
Never had an issue with mine but that is because I usually throw a Baker Chain Tensioner on for peace of mind upon getting the bike. I consider it preventative maintenance, $200+ is a hell of a lot cheaper than tearing the primary apart for bearings and what not. Also you DO NOT have to remove the Comp to install it.
Old May 17, 2017 | 02:34 PM
Two Lane Tramp's Avatar
Two Lane Tramp
I am at 35K and "NO" issues with stock setup. I heard all the chatter so check tension every 10K. Always in perfect adjustment.
Old May 17, 2017 | 02:37 PM
Jackie Paper's Avatar
Jackie Paper
How do you do that? How much play do you see?
Old May 17, 2017 | 03:59 PM
Cobra1's Avatar
Cobra1
Yes there are failures but the vast majority work as designed of the life of the bike.
Old May 17, 2017 | 05:01 PM
hardheaded's Avatar
hardheaded
how are you installing the baker unit without first removing the compensator ?
Old May 17, 2017 | 05:04 PM
Jackie Paper
The tensioner comes off with both the clutch hub and compensator still on there. You remove it before locking up the drive to remove them if you were taking them off.
Old May 17, 2017 | 05:55 PM
WarHorse15's Avatar
WarHorse15
^^^ What he said. Plus the Baker Tensioner can be taken apart and re-assembled behind the chain while it is still on the bike.
Old May 17, 2017 | 06:00 PM
ElectraJim's Avatar
ElectraJim
The stock auto chain tensioner that I had on my bike was a piece of crap. It would keep ratcheting up so the chain was extremely tight. I finally installed a Baker Attitude Adjuster. I had to remove the compensating sprocket and clutch to install it. I tried to take it apart and I still couldn't get it behind the chain.
Old May 17, 2017 | 06:50 PM
WarHorse15's Avatar
WarHorse15
Interesting. Mine went on easy with little fuss. I thought I did need to remove comp until I saw a post saying you just needed to take the Baker unit apart. Sorry it didn't work for you.
