Intercom Communications
Old May 28, 2017 | 10:00 AM
stubandt's Avatar
stubandt
Stage II
Default Intercom Communications
Purchased new 17 Ultra Limited and purchased second rider headset. Rider and passenger can both hear radio/bluetooth music but we cannot hear each other on intercom despite that being turned on, volume adjusted, and intercom icon on screen illuminated when either of us speak. We also hear the music volume lower when either rider of passenger attempts to speak. Very frustrating and annoying, particularly since Harley makes you purchase second headset.
Upset owner of two Harleys! Help
Old May 28, 2017 | 10:21 AM
emu309's Avatar
emu309
Sounds like you need to adjust the volume. Begin to speak and adjust the volume while speaking.
Old May 28, 2017 | 10:48 AM
cycle7447's Avatar
cycle7447
Community Influencer
stubandt - congrats on the new bike. Please don't get frustrated. It just takes a little time to understand the Boom system.
emu309 is correct. The fact that you hear the radio and that the vol goes down when you talk tell us that the system is working. As he mentioned, please adjust the headset volume while talking.
Do this... both put on headsets. Rider talks into the mic..and while the rider is doing that, the passenger turn the vol up from the rear.
Next, passenger talks into the mic..and while talking, the rider turns the vol up.
All of your audio works that way including the CB (if you have one). Make the adjustment while using that particular component.
Let us know how you make out...and, enjoy the bike.
Old May 28, 2017 | 12:24 PM
rwven's Avatar
rwven
Be sure the headset cord is fully seated into the headset. I have one headset that it keeps working loose on. It only has to be out a little bit to prevent the intercom from working.
Old May 28, 2017 | 12:31 PM
Hammz's Avatar
Hammz
Because you are seeing the intercom icon on the screen, you have the intercom turned on. That does not mean the vox (intercom) is active. The intercom icon changes between on & active.
If vox sensitivity is high enough to activate the intercom, the icon changes. This adjustment will be critical if you are using speakers for radio/music; too high & it will activate vox (intercom) w/o speaking, too low & vox won't activate (no intercom). Also if vox is set too high, wind noise will activate the intercom.
Microphone placement is also critical to proper operation. Adjust the microphone boom to place the end of the boom to the left corner of your mouth, just touching the lip at the edge of your jmouth. You will need to talk at or slightly above normal speech volume for proper operation.
When you have the vox working properly, while talking (vox & intercom active), adjust the volumes for the rider & passenger. Note: intercom volume adjustment requires the vox (intercom) to be in the active mode.
Our '14 Limited has CB & driver PTT switch. When my wife & I ride alone (not in a group) we turn the CB off & use the PPT switches to activate our intercom. We usually listen to music on the bike's speakers & have the vox sensitivity adjusted low so that it won't activate w/o using PTT.
Enjoy the ride!
Relevant excerpts from the manual:
Old May 28, 2017 | 12:33 PM
Hammz's Avatar
Hammz
Old May 28, 2017 | 02:10 PM
harley0711's Avatar
harley0711
headsest plugs are a PIA - most NEED to be either zip tied OR run back UNDER the clamp - IF cable/plug is left to dangle - IT WILL pull and shut OFF communications... confusing but you will eventually get it
Old Jul 4, 2017 | 02:56 PM
swellmiller's Avatar
swellmiller
3rd Gear
Default Music bluetooth
We find the music isnt loud enough to hear is there anyway to get more sound out of the headset speakers?
Old Jul 4, 2017 | 05:25 PM
cycle7447's Avatar
cycle7447
swellmiller- yes, you can turn the headset vol up. Do so while the music is playing. Or, you can go to the setting (depending on your bike)
Old Feb 18, 2018 | 03:50 PM
rinja64's Avatar
rinja64
Hammz, thanks for the info. I have done all the things outlined except using PTT. I will try that. I recently purchased a new upgraded headsets plus cords from J&M for myself and my wife. During our last ride, the mic kept activating. I adjusted the VOX thinking it was wind but this was different. It was more stable intermittent activation then just frequent wind activation. Seemed like every 5 seconds it would activate. I checked both connections at the helmet and at the mid section of the cords plus bike connections.
Weird but wondering if you had any ideas. We have a 2015 Limited Low. Prior to that an 02 Ultra with no issues so we have a few thousand miles.
Thank you,
Jay
slowrollin
Oct 1, 2020 12:45 AM
Harley720
Sep 10, 2017 06:07 PM
Loripatt
Feb 25, 2017 08:45 PM
pworks
May 13, 2015 08:48 PM
NCBondsman
Dec 16, 2013 03:54 AM
