Snapped spark plug using torque wrench
Old Sep 29, 2017 | 07:45 PM
Hog happy's Avatar
Hog happy
Default Snapped spark plug using torque wrench
FYI, I have always tightened plugs without a torque wrench. I changed plugs in my 103HO Road Glide and decided to use a torque wrench set at 16ft lbs, in the middle of the specified range. Used a little anti-seize as the book says as well. Tightening and waiting for the torque wrench to activate on the second plug and snapped the plug flush with the head. Luckily I was able to back it out. From now on I will be going back to using a ratchet only. By the way, these were Champion plugs and the area that snapped looks like pot metal.
Old Sep 29, 2017 | 07:58 PM
pswomack's Avatar
pswomack
I've watched many rookie mechanics make the mistake of using a torque wrench on plugs, either break the plug or strip the threads out!
All you need is hand tight, then 1/8 to 1/4 turn (45-90 degrees)
Old Sep 29, 2017 | 08:04 PM
Screamin beagle's Avatar
Screamin beagle
That's such a sickening feeling when you snap something off on your motor...glad you got it out. I agree with the rachet only method mentioned above
Old Sep 29, 2017 | 08:09 PM
sixguns's Avatar
sixguns
Torque wrenches and common sense go together, I always use both.
Old Sep 29, 2017 | 08:24 PM
IUOE ROB's Avatar
IUOE ROB
I remember reading that you should reduce torque value when using anti-seize. I know it doesn't specifically say it in the article below but threads coated with anti-seize are considered "lubricated". This article recommends reducing by 25%...
https://www.antiseize.com/PDFs/torqu...ifications.pdf
Old Sep 29, 2017 | 08:51 PM
PeteF's Avatar
PeteF
I use a torque wrench on most things, but not spark plugs. Just gently snug them. Another thing to remember is if 16 ft lbs is at the lower end of your torque wrench's scale, it may not be all that accurate.
Old Sep 29, 2017 | 09:00 PM
QC's Avatar
QC
When lb-ft values get that low, I make the conversion and use my lb-in wrench.
Glad you got it out with no trouble.
I do not use a torque wrench on spark plugs, never have.
Old Sep 29, 2017 | 10:25 PM
KrustyKush's Avatar
KrustyKush
I guess I've been lucky. I've used torque wrenches on plugs ever since I could afford one. I still have a Western Auto wrench I bought in 1969.
I've never broken a plug. In fact I changed out my plugs yesterday.
I've tended to use anti seize on plugs in Japanese motors until I read that it isn't wise. I was surprised to see that Harley says to use it on theirs.
Old Sep 30, 2017 | 09:38 AM
Brewmany's Avatar
Brewmany
I've never snapped off a spark plug, and I've used regular as well as torque wrenches over the years. How much force on the wrench would you have to apply to break off the plug?
Seems to me it'd be a lot- wouldn't the bigger risk be stripping out the threads in the head? Just wondering.
Once the wrench went past about a quarter turn, why didn't you back off?
Old Sep 30, 2017 | 10:02 AM
rwven's Avatar
rwven
Or use a beam or dial type torque wrench. The "click" type generally can't be trusted at the lower ends of the scale. Especially the cheaper wrenches...which is what I have.
A second on the lubed threads reply also. You need to reduce the torque significantly if you use anti-seize or oil on the threads.
