I always use it and it's also very convenient to just do so. Also for the person who indicated that by using the kill switch you may forget to turn the ignition switch off; another good habit to develop is to always lock your bike even if you are only going to be a short distance away. I was only about 20ft away from bike in 1974 when my 1973 flh was stolen, grant it there was a wall in between me and the bike so I could not see what was happening and a lot of people watched it happen. All I ever got back was a striped frame.
I do not. It was placed there so if you crash in front of me, I can shut off your motorcycle quickly by locating the right handle bar. I do not have to search your entire bike for the ignition key location. Who wants a redlined Harley next to you when you are trying to apply pressure to a wound and trying to talk to the rider?
Also they fail,just like kick stand switches. When they fail, you have a very heavy push bike. I had a R75/6 with a failing kill switch. I've been on the road when others have been unable to make the kill switch contact due to corrosion and or grit.
Some brands the contacts are barely large enough to handle the current. As they wear, they become more troublesome.
So I will not, but if you do, so be it.
Things do occasionally fail, sure do. I had an ignition switch fail once as well, so I just pull my plug wires, then disconnect my battery, works every time...
Been using the kill switch since '68 without issue, use to be a kill button built right into the handle bar. Kill button on the right and and a button that looked the same on the left was the horn.
The XLCH, didn't have a battery so no issue leaving any electric on, but today (non cvo) after shutting down with the kill switch you want to remember to turn the ignition off.
