Kill Switch
Old Nov 16, 2017 | 10:47 AM
  #31
danhahn's Avatar
danhahn
Ignition switch. Why make a two step process out of something that one step does just fine.
Old Nov 16, 2017 | 10:49 AM
  #32
Brewmany's Avatar
Brewmany
Originally Posted by judgedelta
Shirley you jest...
I'm not jesting, and DON'T call me Shirley!
Old Nov 16, 2017 | 10:51 AM
  #33
Brewmany's Avatar
Brewmany
Originally Posted by Weeboy1
just curious , even if the manual suggests it. is there any detriment to only using ign switch. Or is there a reason to use KS and then Ign.
So far in over 10 years of motorcycling (HD and Japanese), no problems just switching off the ignition.
But I also peel the warning stickers off the air cleaner, and we're getting a new bed delivered tomorrow, so don't tell anyone, but I'm yanking off that mattress tag.
I'm a badass
Old Nov 16, 2017 | 11:04 AM
  #34
Cygnusx51's Avatar
Cygnusx51
I'm a badass
Welllllllll, only half a bad ***. The tags can be removed by the consumer, it’s only illegal for the manufacturer and retailer to remove them. But surely you knew that lol.
Old Nov 16, 2017 | 11:28 AM
  #35
hardheaded's Avatar
hardheaded
been riding for 50 plus years and never used the kill switch. WHY ?
Old Nov 16, 2017 | 01:58 PM
  #36
White Ice's Avatar
White Ice
Originally Posted by HarleyBP
I didn’t until I checked the manual. Recommended way to shut off bike, kill switch then ignition.
As described on page 138 of the Touring Models Owners Manual 2016
Old Nov 16, 2017 | 03:31 PM
  #37
dyna07custom's Avatar
dyna07custom
Originally Posted by rwven
I use the kill switch.
me 2
Old Nov 16, 2017 | 03:54 PM
  #38
TSheff's Avatar
TSheff
Never have. I forget it's even there. Dropped the bike once running the Twisted Sisters, got it up right, checked damage (minimal), and took time to chill a little. Bike wouldn't start and I couldn't figure why. Double checking, must have hit the KILL while going down, that's the only time I know of that mine has been off (other than just testing switches after bar swaps or harness changes).
Old Nov 16, 2017 | 03:59 PM
  #39
GalvTexGuy's Avatar
GalvTexGuy
I seem to vaguely remember a time if you turned off the motor with the kill switch before the RPM reached its happy place (1K RPM) that the ECM would use that as the default RPM. For instance, say you just started your cold bike and the RPM was ~1.4K and for some reason you immediately turned off the motor using the kill switch. The next time you start the bike, even if it is warm enough that the idle should be at its happy place, it will idle at 1.4K instead. Does this still hold true?
Old Nov 16, 2017 | 05:00 PM
  #40
Cygnusx51's Avatar
Cygnusx51
^ I remember reading about that and I think you had to cycle the ignition a few times to reset the high idle symptom. Not sure if it’s still a thing though.
