Kill Switch
Old Nov 16, 2017 | 07:39 PM
  #41
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
I have always been trained that you want to use the kill switch. It is right where your hand is and in our emergency you don't have to take your hand off the bars to kill the engine.
That said back with my 2008 and 2010 if you had your hand on the grip you could easily reset the throttle position causing idle RPM to change. I did start using the lock switch every time I cut those bikes off.
Now with the CVO the only option is the kill switch on the bars so I am back to where I began and it feels right!
Old Nov 17, 2017 | 08:37 AM
  #42
Harttoo's Avatar
Harttoo
I was told by the sales person to use the kill switch first,then ignition switch. This is important on Rushmore bikes, to prevent voltage spikes that might harm the electronics.So, I have made it a habit.Always use kill switch ,then ignition.
Old Nov 17, 2017 | 08:41 AM
  #43
tpcowfish's Avatar
tpcowfish
I was told the same by my dealer
Old Nov 17, 2017 | 10:11 AM
  #44
Tired's Avatar
Tired
I ride so much I never shut mine off. We don't need no stinking switches!
Old Nov 17, 2017 | 11:27 AM
  #45
vizcarmb's Avatar
vizcarmb
Only Metric riders never use their kill switch.
REAL HD bikers use the 2 step process
Old Nov 17, 2017 | 11:45 AM
  #46
rwven's Avatar
rwven
I don't know about that but "real HD bikers" thing but I am pretty sure I'll never be caught by the "turn off his kill switch" prank again.
Old Nov 18, 2017 | 01:13 AM
  #47
Madd Max's Avatar
Madd Max
Rwven, don’t feel bad I pranked myself one day when I stopped for gas. I hit the kill switch by mistake. Took about 15 minutes before I realized what I did. I have never used the kill switch. The thing about it is between me and 2 friends that were with me that day we have over 80 years of riding experiences and it took that long to figure out. We still laugh at that one.
Old Nov 18, 2017 | 05:17 AM
  #48
Ron750's Avatar
Ron750
I always hit the Kill switch. Then I turn front wheel to lock, and move ignition switch to lock. All one habit.
The one time I dropped my bike.and needed the kill switch it happened so fast the tilt switch killed the engine before I did.
Old Nov 18, 2017 | 05:18 AM
  #49
Ron750's Avatar
Ron750
Old Nov 19, 2017 | 05:32 AM
  #50
ADVNTR's Avatar
ADVNTR
Be nice to your electrical system - use the kill switch.
...and be nice to each other while playing keyboard cowboys.
Rather than provide further technical explanation - enough has been provided already - just do it - I am not here to convince the misinformed that like to do it the other way.
I can't believe people want to argue about the correct operation of a motorcycle.
