7 pin headset audio issue
Old May 16, 2018 | 12:20 AM
Hawkeyes and Harleys's Avatar
5th Gear
Default 7 pin headset audio issue
Hey all, I recently upgraded to a 2016 Ultra CVO and am still learning the Boom audio system. I've tried using the headsets from my 2007 Ultra and I can hear everything to include phone calls just fine, but have no audio output. A caller cannot hear me...the bike doesn't hear any of my commands and it's the same result on two different headsets. What am I doing wrong? Again, I can hear everything through the headset...no-one (including the bike) can hear me. TIA
Jason
Old May 16, 2018 | 06:20 AM
14GuineaPig's Avatar
14GuineaPig
Did you adjust the VOX settings? I think you can also try using the PTT switch to se if that works.
Old May 16, 2018 | 10:13 AM
5th Gear
Tried both...no luck.
Old May 16, 2018 | 11:43 AM
cycle7447's Avatar
cycle7447
Community Influencer
Plus the headset into the rear connector - see if anyone can here you. If so, you might have a bad plug upfront
Old May 16, 2018 | 12:05 PM
sailmotion's Avatar
sailmotion
Your heading mentions "7 pin" and I believe that is the correct connector for a '16; however, if you used a cable from your '07, I believe that was a 5-pin. So your problem may be a connector incompatibility.
Old May 16, 2018 | 12:26 PM
biglew55's Avatar
biglew55
You might look to see if the prior owner added the WHIM. It is known to foul up the wired headset functionality in exactly the way you describe, by not passing mic outputs.
ronbridgefarmer
Audio Systems
Mar 10, 2022 03:38 AM
Gilkazson
2014-2024 Touring Models
Feb 23, 2015 04:08 PM
wojo1965
Feb 15, 2014 09:27 AM
ictdog
Jul 14, 2013 09:12 PM
yorgo
Dec 1, 2010 07:46 AM
