2016 Street Glide Running On One Cylinder
Old Sep 3, 2018 | 07:56 PM
Django's Avatar
Django
Default 2016 Street Glide Running On One Cylinder
2016 Street Glide Special
Mods
Khrome Works 2 into 2
Heavy Breather
Andres 57 cams
Adjustable Pushrods
TTS Tuner
Tuned on Dyno
4800 miles on bike
Riding today getting into it pretty good bumping limiter up to 6th gear. Around 4800 in 6th gear bike bogs down no smoke or strange noises. seems to be running on one cylinder. Getting code P1353, P0502 and P0503
Wont start or stay running except at half throttle.
Trailer'd home.
Any ideas what might be going on?
Thanks in advance
Ted B
Old Sep 3, 2018 | 08:50 PM
GalvTexGuy's Avatar
GalvTexGuy
VSS. Do the turn signals and the speedometer work?
Old Sep 3, 2018 | 08:56 PM
Django's Avatar
Django
Yes on both
Old Sep 7, 2018 | 12:23 PM
gigihurt's Avatar
gigihurt
Any updates?
Old Sep 7, 2018 | 02:02 PM
Hammz's Avatar
Hammz
Check plug wires?
Sounds like the front cylinder plug wire may have rubbed through where it contacts the gas tank.
Codes are:
P1353 - no combustion in front cylinder
P0502 - VSS failed low
P0503 - VSS failed high
Old Sep 8, 2018 | 06:48 PM
Django's Avatar
Django
Lock nut backed off of front intake push rod. Was surprised no rattle or pre-warning. Cylinder just died under heavy acceleration.
TB
Old Sep 8, 2018 | 09:07 PM
Hammz's Avatar
Hammz
TB
Glad you found it!
Old Sep 8, 2018 | 09:13 PM
PadreFreddie's Avatar
PadreFreddie
Sh*t man, what are the odds of that happening? If it was raining big fat p*ssy today you would have gotten hit on the head by the only d*ck that fell out the sky...glad you found it!
Old Sep 8, 2018 | 10:16 PM
Django's Avatar
Django
Yes just my luck
Old Sep 10, 2018 | 04:55 PM
memphisharley's Avatar
memphisharley
I actually had the same issue a few weeks ago. Make sure you red lock tight those nuts.
Paul Maxwell
Mar 29, 2019 07:49 AM
Streetgld46
Mar 20, 2017 12:09 PM
GfromAlberta
Jun 7, 2012 12:26 AM
danstoys
May 21, 2012 08:38 PM
treadstone
Mar 12, 2012 10:06 AM
