14" Bar question
Old Sep 19, 2018 | 11:41 AM
blueangel73's Avatar
blueangel73
Default 14" Bar question
I am looking at changing out my bars and would like to go with 14". I have a 2016 RG without ABS and according to West Coast T-Bars, I would need to change out my lines and add wire extensions. I have watched videos where people have put 14" apes on a Rushmore RG and used the stock lines. I don't know if those bikes had ABS or not, so I don't know if what WCT-B is saying is factual or not. Can someone answer this, do I or do I not need to change the lines of my 16' FLTRX to add 14" bars?
Old Sep 19, 2018 | 04:24 PM
whocares's Avatar
whocares
The 14's WILL work with stock lines and wires!
Old Sep 19, 2018 | 04:59 PM
Stroked16's Avatar
Stroked16
this should help. You can use stock wires/cables for up to 14" bars.
Old Sep 19, 2018 | 08:47 PM
UltraWalt's Avatar
UltraWalt
You do not need wires extension and cable. I have 14” bars and I have ABS and honestly, I might even be able to fit 16” without extending wires and cables.
Old Sep 20, 2018 | 08:31 AM
blueangel73
Thanks for the replies.
According the WCT-Bars a Rushmore Road Glide with ABS has longer lines and wires, thus can receive a taller 14" bar. But a Rushmore Road Glide without ABS has sorter lines and wires, thus not long enough for a 14" bar.
I am looking for someone not running ABS that can confirm or deny WCT-Bars claim.
Again, thanks for the help.
Old Sep 20, 2018 | 10:29 AM
INJEKTER's Avatar
INJEKTER
Originally Posted by Stroked16
https://www.youtube.com/watch?v=gTl5JIEre30&t=482s
he is asking about a Road Glide....not a Street Glide..
Old Sep 20, 2018 | 11:34 AM
Kermie's Avatar
Kermie
IMHO I would play it safe, and get the proper extensions. If the wires/cables are shorter on the non ABS, then get them. My cables on my 12" Yaffes were pretty much at the limit, after cutting some zip ties. Now the Yaffe bars measured out to 13.6" or so but this was on my Special so with ABS.
Old Sep 20, 2018 | 01:32 PM
blueangel73
I usually fit the bars and see what I need to change and order as needed and once everything is in, I do the swap. I was looking to see if anyone had any hands on experience with the conditions I will be working with and trying to learn from them. I have learned that often a manufacturer will suggest things that are necessarily needed but still considered wise advise to cover their reputation and not be accountable for person mistakes. But thank you for letting me know you were working with a non-ABS bike.
Old Sep 20, 2018 | 03:33 PM
Stroked16's Avatar
Stroked16
......my mistake, link was for wrong bike. Good thing google is our friend and providing the same video for a Road Glide only took a millisecond off my life. More importantly, it can still be completed without changing cables or wires.
Good luck OP.
Old Sep 20, 2018 | 05:56 PM
INJEKTER's Avatar
INJEKTER
https://www.youtube.com/watch?v=ja0nJaMNraE
Good luck OP.
yea... i used the Street glide video when i did my bars, no extentions needed... but i could not answer cause no RG experience
