breather venting
Old Dec 1, 2018 | 12:54 PM
lanzar4155's Avatar
lanzar4155
Default breather venting
I am running the screaming eagle forward facing heavy breather. 29006-09b on a 2016 SGS Stage 1 kit.
I am trying to research how to run a catch can off this breather. From what I can tell the bolts 29465-08 are what is venting the case. However, they don't really appear to vent anywhere or lead back into the breather.
Does anyone have experience with this that could possible provide me with any information.
Thanks in advance.
Old Dec 1, 2018 | 01:24 PM
GalvTexGuy's Avatar
GalvTexGuy
Old Dec 1, 2018 | 05:14 PM
Softy 103's Avatar
Softy 103
If you pop the two caps off you will see a passage way going to the throttle body, the bolts are hollow.
Old Dec 2, 2018 | 11:04 AM
lanzar4155's Avatar
lanzar4155
Thank you! Then essentially its not venting anywhere? The caps air lock the housing the bolts are in. So everything just goes back into the head?
I pulled the breather off and had some thick milky oil in the face of the throttle body.
Old Dec 2, 2018 | 11:48 AM
lanzar4155's Avatar
lanzar4155
I pulled the caps off and there was a small amount of milky oil in the housing. It must just settle in there until you clean it out. It appears that once it has made its was through the hollow bold it does not get re introduced into the throttle body.
So my assumption, there is no need to run a catch can as this system is basically a catch can?
Thanks for the help. If anyone has more info and I am missing something please let me know.
Old Dec 2, 2018 | 11:57 AM
Nitro 54's Avatar
Nitro 54
Not all the milky crap is just staying in the throttle body. You need to vent it somewhere else.
Old Dec 2, 2018 | 12:13 PM
Mchad's Avatar
Mchad
There are two conduits from the breather bolt standoffs that run to the throttle body opening. They most definitely vent to the intake. If they didn’t you’d be blowing seals due to the crankcase overpressuring.
To vent externally you will need to plug those passageways, drill a hole at the bottom of the breather bolt standoffs and install some hose barbs to run fuel line (oil resistant) to wherever you want to vent to.
Old Dec 2, 2018 | 12:15 PM
Mchad's Avatar
Mchad
Old Dec 3, 2018 | 11:47 AM
hbsoldier3's Avatar
hbsoldier3
Old Dec 3, 2018 | 03:38 PM
lanzar4155's Avatar
lanzar4155
Thanks I see the holes now.
Did not really want to drill into the bracket.
Thoughts on the pro's of a catch can?
