Valve / Top End Noise
Old Apr 23, 2019 | 01:43 PM
rusty289's Avatar
rusty289
Default Valve / Top End Noise
Has anyone had any success in eliminating top end/valve noise?
I've done the rocker lockers and still have the issue, it's annoying as hell!
2015 Road Glide, added cams a couple years ago but I'm convinced the noise came or became very noticeable when I switched to Amsoil.
I don't want this to turn into an oil thread but I'm considering switching back to dino oil, HD or otherwise.
I know the motor was quieter with the HD oil in it.
Thoughts?
Old Apr 23, 2019 | 01:58 PM
hbsoldier3's Avatar
hbsoldier3
Thoughts?
I switched back to dino oil, Spectro 25W60 and it quieted down the noise considerably.
Old Apr 23, 2019 | 01:59 PM
Bafflingbs's Avatar
Bafflingbs
Have you tried to go to an adjustable push rod? That might help to clean up the slop. Next thing to try, might be new springs or roller rockers. I'm not a mechanic nor have I ever been inside my engine, but, I think I know how they work. If those ideas don't work, I wonder if you have an oil flow issue. What is your oil pressure?
Old Apr 23, 2019 | 02:28 PM
ROCKOUT Rocker Products
Sponsor
Best advice you will get here
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Apr 23, 2019 | 02:52 PM
hbsoldier3's Avatar
hbsoldier3
I was gonna mention your user name as my source for my post, but could not remember it completely, thanx.
Old Apr 23, 2019 | 04:30 PM
GalvTexGuy's Avatar
GalvTexGuy
Thoughts?
Too late.
Old Apr 23, 2019 | 04:39 PM
Tired's Avatar
Tired
Klotz 25W60 Syn works pretty well also.
Old Apr 23, 2019 | 06:40 PM
tesnevo's Avatar
tesnevo
amen 1000 times to that. Makes all the difference in the world on mine
Old Apr 23, 2019 | 07:16 PM
pswomack's Avatar
pswomack
Exactly what I use in mine, 110SE bolt on kit, Woods TW777 Cams, Fuel Moto adjustable push rods, Rocker Lockers, Heads ported and polished by Big Boyz Porting, When I ran Amsoil it had really bad valve train noise, same with HD Syn3 and also Mobil 1 Full synthetic, but with the Spectro 25W60 there is very little noise now, That's what I would suggest!
Old Apr 24, 2019 | 06:42 AM
rusty289's Avatar
rusty289
Adjustable push rods went in with the cams, along with new lifters. Even checked the push rod adjustment after install then again after the Rocker Locker install.
As for roller rockers and or new springs, bike only has 15k miles on it.
I think an oil switch is in the cards. Don't think I've ever heard of or seen Spectro Oil around my area.
