CB issues
Old Jun 19, 2019 | 07:28 PM
Sapman's Avatar
Sapman
Default CB issues
My CB has become very noisy. Today, I had to bump up my squelch to three bars above mid point to get it to quit. At that level, I cant hear anyone trying to talk to me. I noticed when I was getting static, the radio was showing the CB in use as if someone was transmitting. My wife said she was not getting any transmissions when mine was showing them. Seems to gotten worst over the last two days to where I can’t use the CB at all. Any ideas??
Old Jun 19, 2019 | 07:47 PM
GalvTexGuy's Avatar
GalvTexGuy
Mine doesn't do that because I never use it. Hope that helps.
Old Jun 19, 2019 | 08:39 PM
top0211's Avatar
top0211
Check the ground wire on the antenna.
Old Jun 19, 2019 | 08:44 PM
davep's Avatar
davep
you have a bad antenna....had same problem...….
Old Jun 20, 2019 | 06:38 AM
K Melancon's Avatar
K Melancon
Check your antenna that the CB antenna (marked CB at bottom) is on the right side of trunk.
Open trunk, behind seat down by seat screw area you will see the antenna coax cable connection, put some dielectric grease of antenna connection. May need cleaning there.
I have had both of these problems on bikes. Dealer put antenna on wrong side and had water get into connection over time.
Old Jun 20, 2019 | 06:43 PM
Hammz's Avatar
Hammz
Before you start tearing into things, give things a while. I say this because when riding this week, I've been noticing "band openings". What that means is that the band noise level is higher because of skip. Skip is when a signal well beyond the horizon can be heard even over local signals. Ask any HAM radio operator & they should be able to provide more insight.
Old Jun 22, 2019 | 02:03 AM
Dr. Tiki's Avatar
Dr. Tiki
^^^ this ^^^
Old Jun 22, 2019 | 09:14 AM
Hammz's Avatar
Hammz
It's not the ground or antenna. It's band conditions.
Old Jun 22, 2019 | 12:31 PM
Happyharley's Avatar
Happyharley
I've had my CB Module replaced twice under warranty because of this issue. Both times just after heavy rain storms.
Haarley
Jul 25, 2018 10:19 AM
cycleman50
Jul 17, 2013 11:43 PM
1roadcaptain
Feb 7, 2012 06:10 PM
nmfxstc
Dec 16, 2008 08:19 AM
Casper
May 3, 2008 11:55 PM
