WHIM - again
Old Jun 28, 2019 | 02:52 PM
Hammz's Avatar
Hammz
Originally Posted by merlin41
The VOX function: if turned on - the passenger mic is open all the time regardless of the sensitivity setting. With the VOX turned off - the intercom function works only by using the PTT button which is unacceptable.
With VOX off, Intercom function only works using PTT button is correct operation (works the same as wired headsets).
Adjust (lower) the passenger mic gain on the Passenger BT headset. The adjustment you're looking for is INT-Audio Sensitivity. Settings are 1 to 10 with 1 being lowest sensitivity. Factory setting is 6. Try setting to 3 or 4.
slowrollin
Oct 1, 2020 12:45 AM
RG Pilot
2014-2024 Touring Models
Apr 9, 2019 11:02 PM
cycle7447
31
Sep 6, 2018 04:57 PM
Loripatt
Feb 25, 2017 08:45 PM
tmichelena
Mar 31, 2014 12:16 PM
