Boom 6.5 and ride planner questions
Old Jul 30, 2019 | 03:12 AM
Hammz's Avatar
Hammz
Steelerdude -
Looks like you are a fast study.
Tips?
  • Ride Planner (RP) adds new "routing points" as destinations, right click & change to waypoints
  • Routes are saved as "?.GPX" files
  • RP routes have start & end destinations
  • RP GPX files can & will contain multiple routes if the planned route contains multiple destinations
  • RP GPX file names are not necessarily the same as the ROUTES contained within that GPX file
  • GPX files are HTML code format; if you know HTML, any text editor can be used to modify the HTML code
  • USB stick is required to import routes into 6.5GT
  • format your USB stick as FAT32
  • GPX files must be in the USB drive root directory
  • when importing a GPX file that contains multiple ROUTES the 6.5GT provides the option to import "ALL" or just specific ROUTES which will be listed by name below the ALL option
  • ROUTE specific names, as displayed in the import menu, will be available to choose under the "where to, routes" menu but the GPX file name will not
  • while up to 99 waypoints can be used within a route, better performance is seen by limiting to <55 points
  • for best results getting the planned route to match the actual 6.5GT directions, plan your route as shortest & then set 6.5GT preferences to shortest as well
  • while running a route, you can stop & shut off the bike; when you restart, wait until the Nav becomes ready before proceeding (not waiting for Nav to be ready will confuse the gps & cause incorrect directions)
I'm sure I could think of more tips, but this list should get you going.
Old Jul 30, 2019 | 05:30 AM
steelerdude1's Avatar
steelerdude1
Originally Posted by Hammz
Steelerdude -
Tips?
WOW! Awesome info, thank you so much for taking the time to share.
Old Jul 30, 2019 | 10:38 AM
Ddieselsmoke's Avatar
Ddieselsmoke
I guess I need to play with my 6.5 more. I get aggravated with it and turn gps on my phone.
Old Jul 30, 2019 | 11:13 AM
14cvoultra's Avatar
14cvoultra
This is a much better route planner and easier to use.
https://www.myrouteapp.com/en
When you build your route in myrouteapp if you place a
waypoint just after each turn the infotainment system WILL follow your route.
be sure to use the boombox save option for your year copy to usb stick then
take it to the bike select import to bike.
Old Jul 30, 2019 | 12:22 PM
cycle7447's Avatar
cycle7447
Community Influencer
We all believe that the app we use is better than all the rest.
I use Harley and Honda Route Planner - neither f these cost me any additional money.
The problem I sometimes run into is - I plan the app on my PC and import it to my bike, no problem. Sometimes, when I star the route, it does not appear that my home address is showing as the starting point - nd the system keeps trying to take me back home first - to start the trip.
Old Jul 30, 2019 | 03:56 PM
Hammz's Avatar
Hammz
Yes, this can happen. Don't start from the first location. Start on 2nd or 3rd point on the route & it won't try to reroute you to that first location.
Old Jul 30, 2019 | 04:20 PM
14cvoultra's Avatar
14cvoultra
as soon as you start the route skipp that waypoint
Old Jul 30, 2019 | 04:30 PM
robbie52's Avatar
robbie52
Even if you have the same criteria (shortest, ect.) in ride planner and Boom 6.5, it will still re-route you on occasion. Use waypoints to keep you on the route that you want to take.
Old Jul 30, 2019 | 04:41 PM
Hammz's Avatar
Hammz
Absolutely. As a general rule, I'll place a waypoint near (but NOT IN) any intersection that requires a turn. I generally either generate or fine tune my routes using Route Converter. Works well & has a good support base.
Old Jul 30, 2019 | 07:40 PM
steelerdude1
The 6.5 didn’t make it today, but I did get a notification from FedEx that it will be here tomorrow, but has a signature required. Hoping I’m home in time. But Fed Ex usually shows up at my house between 3-5 regardless of wether it supposed to be a morning delivery.
Hope to get it tomorrow, and start playing.
While I’m Waiting, I’ll ask, On a road glide does the front outer fairing need to come off, or can I access what I need with the top of the fairing off. I Know, not a big deal to remove, but just curious.
