Advan Black Tour Pak with Harley LED Light
Old Mar 10, 2020 | 05:53 PM
lhgdale's Avatar
lhgdale
Default Advan Black Tour Pak with Harley LED Light
Hello, I'm wanting to get a Advan Black king tour pak for a 2018 Road Glide Special. Does anyone know if the Harley LED Tour-Pak brake/turn/tail lamp will fit the tour pak? From what I have read I will need a tour pak wiring harness to make it work.
https://www.harley-davidson.com/stor...11-67800368--1
Thanks for the help.
Old Mar 11, 2020 | 10:49 AM
piper59's Avatar
piper59
Advan Black is a copy of the HD tourpak.Can't see where it wouldn't.
Old Mar 11, 2020 | 11:06 AM
Extricator's Avatar
Extricator
I just did a color matched King Tour Pack from Advan Black and will be ordering the Harley light kit also. I contacted Advan Black and they said the 2014 and up lights will fit their tour packs....Just need to get the template also. Not sure if a template comes with the kit yet.
Old Mar 11, 2020 | 01:32 PM
Circa58's Avatar
Circa58
I mounted a stock Harley Rear Light on my Advanblack King TP
Old Mar 11, 2020 | 03:09 PM
lhgdale's Avatar
lhgdale
Thanks for the info guys! I also read that you can get a tour pak wiring harness from Harley and it will be a plug and play install for the light.
Old Mar 11, 2020 | 03:23 PM
Circa58's Avatar
Circa58
Or Custom Dynamics as well for a harness
Old Mar 12, 2020 | 10:20 AM
Custom Dynamics's Avatar
Custom Dynamics
Former Sponsor
You can check out our Tour Pak Quick Disconnect/Wiring Harnesses & Adapters, here: https://www.customdynamics.com/categ...ck-disconnects Or, give us a call (1-800-382-1388) and we can answer any questions you might have/help you place an order!
Old May 8, 2020 | 09:31 PM
toddhud's Avatar
toddhud
Stage III
Did you find a template? If so can you share where to get one? The kit I bought did not come with one from HD. Thanks!
Old Mar 13, 2021 | 11:30 PM
Smeej's Avatar
Smeej
Stage III
I’m interested as well. Still confused on which harness(s) to order for the rear led running/brake/turn light and the side lights. I thought it would be an easy task to add the tour-pak to my RGS lol
Old Mar 16, 2021 | 07:01 AM
MCSarge's Avatar
MCSarge
this is what I used for my Tour Pak. Great company, I had an issue with a windshield light not operating properly and I called them and their tech Barry Buker called me right away, asked what was going on and suggested how to fix it. Turned out when I put the RG outer fairing back on I switched a couple of plugs. Fixed that and all was good. Barry even emailed me back on Monday to make sure I got it straightened out. All my lights will be CD from now on.
