Eliminate Front Fork dive?
Old May 31, 2020 | 05:50 AM
Dynamick's Avatar
Dynamick
Originally Posted by RIPSAW
There are plenty of diet cook books out there....I always assumed if you want a smooth ride, ride a Harley. Want a hard handling ride, ride a Sport bike.
I assumed that too - turns out I was wrong. All three of the sportier bikes I've owned have had a more supple ride than any of the three Harleys I've owned.
I've been able to improve the Harleys' ride somewhat with better shocks but still inferior.
Old May 31, 2020 | 05:56 AM
GOV5's Avatar
GOV5
Originally Posted by Cosmic Razorback
Hey Gov, That is one of the things the new Pro-Action front fork system was designed to do. I rode with George on a test ride when he was fine tuning the system. I was amazed at how the dive disappeared. The kit is not expensive at around $200 bucks. Depending on who you can get to install it the total may not be too bad. I plan to add it to my bike this fall to compliment the Pro-Action rear shocks.
Good luck as I am not familiar with any other add ons that may help.
Thanks Cosmic! $200 for ProAction plus install cost is very doable. Who is George? Do I just Google Pro Action?
EDIT: I just looked at the webpage. George was founder of Pro Action. The 49mm Fork kit, Pro Action Street Series Fork Kit is $315 for my Ultra Classic. That's not bad. I'll as my Dealer how much install will be.
Old May 31, 2020 | 06:05 AM
Sandcrab's Avatar
Sandcrab
Default Confused
When I rode dirt bikes, we wanted as much travel in the forks as we could get. The idea was to let the front tire move up and down as you hit the bumps while you basically sat on the seat. I fail to see what has changed.
I think you still want the front tire to move up as it encounters an obstacle, and drop back down to follow the contour of the road so you maintain tire contact.
On my 2009, I changed to SE Heavy fork oil, and then was unlucky enough to follow riders who took a shortcut on a dirt road. This road had been bulldozed so it had the bumps. My front end was too stiff, and my tires could not keep up so my front end skipped and moved on me. I kept slowing down until it was ridiculous, everyone was passing me. I went home and put the 5 wt back in. On my 2015, I am using 7.5 wt oil and couldn't be happier.
Why would you not want the front tire to move up and down freely?
Old May 31, 2020 | 08:18 AM
GOV5's Avatar
GOV5
For me(not talking for others), it's not the bumps that are causing the issue. After all, what goes up...must come down.
What's causing my issue is the "dive" where there was never any 'UP" motion. There are times when that up and down motion help...like riding over speed bumps. If you apply the front brake heavy when your front tire first hits the bottom entrance to the bump, the rebound back up will carry you over the speed bump without ever feeling the bump at all.
However, when just coming to a stop, and putting both feet down while squeezing the front brake, the front end dives hard. That's NOT where it should dive because no bump was ever hit. I'm not naive either, as I understand forward momentum will naturally cause some forward weight shift just as it does in a car. But not enough to compress the forks half way down. It should be much more gentle that that.
Old May 31, 2020 | 08:32 AM
18deluxerider's Avatar
18deluxerider
if your forks are bottoming on stopping you may not have enough oil in them that will cause them to bottom out.
Old May 31, 2020 | 09:00 AM
GOV5's Avatar
GOV5
I appreciate the tip, really. But every Harley I've ever owned has done the same thing. It isn't the lack of fork oil. It's the lack of a decent suspension system. LOL!
I KNOW what's needed...a better suspension. I'm not sure how much longer I'm going to have this bike. I usually trade about every four years, and I'm there now.
I'm trying to get it a little better..if that's possible..for a "little amount of money"..if THAT is possible. OK, I'M CHEAP! LOL COSMIC gave me the best solution other than just pouring in heavier fork oil.
What I really need to do is decide if I'm going to keep this bike or trade. If my decision is to trade, I'll save my money now and have the dealer put in a new suspension on the new bike at time of purchase. I'm going to look at some different bikes too. I may wind up with an adventure bike which already has a good stock suspension.
Old May 31, 2020 | 09:56 AM
cwsharp's Avatar
cwsharp
It's not really the fork dive to me... it's the impossibility to keep the bike in a balanced position once the fork has to dive... a more gradual 'dive' might make it easier to keep your balance but a touring Harley is just top heavy... not much you can do about that.
Old May 31, 2020 | 11:14 AM
rsking45's Avatar
rsking45
In done heavier fork oil, different rates springs different size spacers, different fork oil levels and nothing really helped. The fork dive was improved but the front end was to harsh for my liking. I even tried progressive suspension mono tubes. Then I can across Pro Action fork kit. This fork kit was so much better than any thing else in done. The fork dive is gone, front end feels so much better. Its a easy install, hardest part is removing the forks. I'm still slowly trying to get the feel I'm looking for, it's close, but I think it can be better. For $300 ya can't go wrong.
Old May 31, 2020 | 11:28 AM
Pantera99's Avatar
Pantera99
Originally Posted by sanman4ever
Add a heavier fork oil. It will do exactly what you are looking for.
Have some Maxima 15 wt fork oil ready to go. Waiting on fork nut socket tool & new fork nut seals to arrive. Have 944 rear shocks that are awesome but have never liked the front end ride. '09 Ultra Classic.
Old Jun 5, 2020 | 09:52 AM
kxbm4h's Avatar
kxbm4h
I changed springs to a progressive front fork set from Revzilla for about a hundred dollars, followed their video and did the work myself, took the brake diving I was getting right out of the picture....
