Eliminate Front Fork dive?
Old May 30, 2020 | 09:55 AM
GOV5's Avatar
GOV5
Default Eliminate Front Fork dive?
There seems to be a lot of talk about suspensions lately. I don't ride enough lately to do much work on suspensions. The stock isn't good, I know that, but for me just cruising around the area, it works for me...almost! But the major thing I would like to eliminate is that horrible front end dive. I don't want to spend $800 to eliminate it either.
Is there an alternative to stock that I can get that will solve the dive issue, or do I just have to put up with it if I don't want to spend $800 or more?
I could get by with something that just REDUCED the dive by HALF, if that exists...any improvement would be a LOT better than it is now.
Thanks in advance folks!
Old May 30, 2020 | 10:05 AM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Hey Gov, That is one of the things the new Pro-Action front fork system was designed to do. I rode with George on a test ride when he was fine tuning the system. I was amazed at how the dive disappeared. The kit is not expensive at around $200 bucks. Depending on who you can get to install it the total may not be too bad. I plan to add it to my bike this fall to compliment the Pro-Action rear shocks.
Good luck as I am not familiar with any other add ons that may help.
Old May 30, 2020 | 10:12 AM
sanman4ever's Avatar
sanman4ever
Add a heavier fork oil. It will do exactly what you are looking for.
Old May 30, 2020 | 11:49 AM
GalvTexGuy's Avatar
GalvTexGuy
A heavier fork oil would be the least expensive way. Even Pro-Action uses Maxima or Bel-Ray 20W fork oil with their front suspension kit. I believe stock Harley Type E oil is 5W, which is why there is so much front end dive.
Old May 30, 2020 | 12:07 PM
sanman4ever
Put this in there. Use the same amount as indicated in the service manual.
https://www.harley-davidson.com/stor...eagle-fork-oil
Old May 30, 2020 | 12:14 PM
sanman4ever
type E = 5wt
type B =10 wt
type se =15 wt
So really any brand fork oil with a 15+ wt
Old May 30, 2020 | 01:20 PM
cwsharp's Avatar
cwsharp
The heavier fork oil helped but didn't fix completely for me. This is probably one of the top HD bad design solutions ever... these bikes handle like crap in my view... they are for riding down a smooth interstate (if you can find one). When I asked the same question I was told that a $2000 upgrade to the suspension components was the way to go. I had a 1983 V45 Honda Sabre... it had a 45 degree lean angle stock from the factory and anti-dive adjustable shocks back then... and outperformed modified HD's, much less stock... top end, quarter mile, handling, you name it. You just have to like Harleys, that's the best fix.
Old May 30, 2020 | 02:19 PM
Cozz's Avatar
Cozz
I just changed my fork oil recently. I used 15 wt Maxima fork oil . Rides better and MUCH less brake dive. There you have it.
Old May 30, 2020 | 02:37 PM
Jackie Paper's Avatar
Jackie Paper
There are plenty of diet cook books out there....I always assumed if you want a smooth ride, ride a Harley. Want a hard handling ride, ride a Sport bike.
Old May 30, 2020 | 06:29 PM
oakmossy's Avatar
oakmossy
what they said!
