Grinding/rumbling feeling.
Old Sep 25, 2020 | 08:40 PM
TheRoadKing101's Avatar
TheRoadKing101
6th Gear
Default Grinding/rumbling feeling.
New to me 2014 Road King with now 9K on it. Noticed when braking, coming to a stop, and only when leaning to the right, a grinding/rumbling feel coming from the front forks. Wheel bearings, brake pads, or something else??
thanks in advance
Old Sep 25, 2020 | 10:52 PM
rcn1963's Avatar
rcn1963
My bet would be wheel bearings. They had a bad batch or something in 2014. They didn't do a recall, but they apparently did pull certain lot numbers off the shelf. I had both front and rear go on my 2014 SGS within the first 10K or so.
Old Sep 26, 2020 | 05:55 AM
TheRoadKing101
6th Gear
​​​​​What brand bearings did you get to replace them?
Old Sep 26, 2020 | 07:29 AM
GalvTexGuy's Avatar
GalvTexGuy
Put the bike up on a jack and get the front wheel off the ground. Visually inspect the bearings and give the wheel a spin. Listen for the grinding noise you're hearing. Take a look at the brake pads, too.
As far as bearings, a lot of owners recommend All *****, but I'm not sure they're any better than the latest revision of the H-D OEM bearings, which is what I used.
The original bearings on my '14 Limited were fine, but I changed them a couple of years ago just because so many people were reporting failures.
I plan on doing the same when I replace the front tire in the near future. Cheap insurance.
Old Sep 26, 2020 | 07:31 AM
TheRoadKing101
6th Gear
I just got new tires put on a month ago. Didn't know about this problem on the 14's then. Or I would have had them check them.
Old Sep 26, 2020 | 09:17 AM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Any good shop will automatically check bearings when you get tires. That is when mine always get inspected.
Old Sep 26, 2020 | 09:20 AM
TheRoadKing101
6th Gear
I don't have a jack to lift the bike. But will be taking it to the shop for them to see what's going on later this week.
Old Sep 26, 2020 | 01:05 PM
wethead103's Avatar
wethead103
If your going to replace bearings, use the All ***** Bearings. These are quality bearings, I used them on my last bike and I’ll use them on my new bike when it’s time to change them out. Good luck
Old Sep 26, 2020 | 01:06 PM
TheRoadKing101
6th Gear
Will do, thanks!
Old Sep 27, 2020 | 12:28 PM
rcn1963's Avatar
rcn1963
The replacements were whatever HD uses. It was replaced under warranty. But they did have to wait a few days for new bearings to come in. The shop said that they had none on the shelf because they had to send everything they had back to HD and were waiting for the replacements to come in. Seems like they said that the new ones actually had a different part number, but I may be thinking "lot number". That was early 2015 I think, so my memory may be off. At the time I was commuting and putting 10-15K per year on the bike. I traded that bike at about 30K without any more issues. So I think, as GalvTexGuy said, they resolved whatever issue they had.
But I also had the front bearings on my 2016 start "leaking rust" probably about the same time. Again...replaced under warranty. I think that was inadequate grease. I never pressure wash. But I do live in Oregon, so riding in the rain is fairly normal.
rcn1963
2014-2024 Touring Models
Mar 9, 2018 02:46 PM
Redrider1998
Wheels/Tires
Apr 30, 2015 09:57 PM
MOSTWANTED
Jul 15, 2014 05:36 AM
garyguitar
Jul 1, 2014 10:31 AM
kegrill
Sep 16, 2012 10:25 AM
