2015 FLHTK radio not working
Old Oct 15, 2020 | 08:59 PM
Time_Traveler's Avatar
Time_Traveler
Default 2015 FLHTK radio not working
I’m looking @ buying this bike and the current owner says everything works on the infotainment except the radio only static?
He says probably only a minor fix like a “wire”
has anyone heard of this issue?
Old Oct 16, 2020 | 03:51 AM
GOV5's Avatar
GOV5
NO. He has screwed up something on the bike. And if it's only a wire, something PROBABLY EASY to fix, why hasn't he fixed it?
Find another bike to buy and from someone that isn't a con artist.
Old Oct 16, 2020 | 04:31 AM
GalvTexGuy's Avatar
GalvTexGuy
First, does the bike have the antenna? Second, is the radio tuned to a radio station, preferably an FM station?
Old Oct 16, 2020 | 05:25 AM
HD_noobie's Avatar
HD_noobie
Also does it work with a USB stick? it will if its just the antenna
Old Oct 16, 2020 | 09:50 PM
Time_Traveler
Thanks
Old Oct 19, 2020 | 07:09 AM
ConfuciusSay's Avatar
ConfuciusSay
Pair it to your phone vis Bluetooth and see if it plays from your music list. If so, might really be just a wire or antennae issue.
Let us know how you make out
Old Oct 19, 2020 | 10:21 AM
hattitude's Avatar
hattitude
Yeah, classic attempt to downplay an issue....
He either doesn't have a clue what's wrong and should say so, or knows full well what's wrong and doesn't want you to know...
In any case, he's hiding something and his dishonesty should be a red flag.... What else is wrong that he's not going to tell you about and may be actively hiding...???
Too many nice, used bikes on the market to roll the dice on a bike being sold by someone playing games...
I'd move on...
Old Oct 19, 2020 | 10:42 AM
rwven's Avatar
rwven
If there is static the radio is "working". Probably an antenna issue. I have a 2014 and I can't recall if I've ever listened to the radio on it.
Old Oct 31, 2020 | 02:03 AM
Vipers Harley's Avatar
Vipers Harley
if he has cheap knock off led lights they could be the issue!
lots of the cheap LEDs will emit RF that knocks out radio reception
Old Nov 9, 2020 | 02:26 PM
Hammz's Avatar
Hammz
I have found on multiple occasions, on multiple bikes, the issue is a loose connection at the antenna/coax interface located inside the tour pack. The AM/FM antenna is located on the rear LEFT side of the tour pack. Right side mount is for CB use.
