Help w/steering stem adjustment
Old Nov 22, 2020 | 11:22 AM
wethead103's Avatar
wethead103
Default Help w/steering stem adjustment
Greetings everyone, I have a 2016 ultra limited cvo with 15,000 mi. I’ve noticed that my front end is not feeling right so I proceeded to do the front end adjustment. Found it was way to tight, it wouldn’t even fall away. As per the service manual I preceded to do the adjustment by removing the fairing and loosening the pinch bolts. Here’s where I ran into the problem. When I put my 1/4” socket extension into the adjustment screw, it would not budge, almost like it was frozen in there. Even with a small cheater bar on my ratchet, Nothing!
Any suggestions on the adjustment screw to get it to move would be greatly appreciated. Thanks in advance!!
Happy Holidays!
Old Nov 23, 2020 | 05:58 AM
Stickman53's Avatar
Stickman53
Don't want to sound like a wise guy.....but...you're turning clockwise (as viewed from below) to loosen right?
Old Nov 23, 2020 | 10:11 AM
wethead103's Avatar
wethead103
I’ve tried turning the adjustment screw in both directions. Manual says turn screw left to tighten bearing or turn right to loosen bearing. It will not turn in any direction. I even sprayed WD-40 up in the neck with no results. I’ll try calling my local dealer and see if they have any suggestions. Thanks
Old Nov 23, 2020 | 10:20 AM
sifularson's Avatar
sifularson
I just took mine apart. When I put the 1/4 extension and ratchet on it, it wouldn’t move at first. Finally it snapped loose and turned easily. I’m guessing it was screwed all the way to the bottom of the threads.
I’m glad I took it apart. There was very little grease on the bearings. 33K on my bike.
Old Nov 23, 2020 | 10:24 AM
twincam10353's Avatar
twincam10353
Just going out on a limb here, maybe the bearing needs to be replaced.
How many miles on your scoot?
Old Nov 23, 2020 | 10:34 AM
wethead103's Avatar
wethead103
It’s a 2016 with 15,000 mi..... I’ll keep trying. It feels like I’m going to break my ratchet.
Old Nov 23, 2020 | 01:08 PM
twincam10353
Try soaking it in PB blaster over night, maybe even applying some heat.
Get yourself some leverage, like a breaker bar.
Old Nov 24, 2020 | 03:50 PM
josame's Avatar
josame
The way I see it, if you are sitting in front of the bike facing the the fairing you will want to push the ratchet to the right to loosen it.
Old Nov 25, 2020 | 09:38 AM
DPete's Avatar
DPete
This is correct, just did mine yesterday and was able to turn the adjustment with a 1/4 drive ratchet. Mine was loose tho. Getting to the pinch bolt was the hardest, had to cut an allen wrench down but finally got it.
Old Nov 25, 2020 | 05:53 PM
wethead103's Avatar
wethead103
Thanks guys for the advise, I’ve worked on it for two days. I’m taking it to the dealer next week, I think I have a badly frozen bearing or frozen adjuster. Thanks again.
Happy Holidays!!
