Hyd vs cable clutch
Old Mar 3, 2021 | 05:51 AM
  #31
eqcons's Avatar
eqcons
Originally Posted by Cosmic Razorback
I guess I am the only guy, other than Matt Laidlaw that prefers the Hydraulic clutch.
I preferRED the hydraulic clutch on my earlier bikes, but of course since it was a perfectly good, working system, the MoCo, in their ever-increasing quest to get cheaper Chinese components had to monkey around with what worked, and ruined it. Look at all the recalls on hydraulic clutches they've had in later versions! Clutch in my '14 FLHTKSE is utterly awful. It's binary, and the lever had to be soooo far out. I did the '19 shim job, (yes, only took 5 years of owners' complaining, as usual) which improved it, but it's nowhere near as good as the hydraulic clutches on my earlier FLHes - they worked, MoCo broke it. And now back to cable clutches - that's ONLY to save them yet more money on making the bikes, but I didn't notice any reduction on the prices of '21 models.
Old Mar 3, 2021 | 09:40 AM
  #32
Hammz's Avatar
Hammz
I like it too, so you're not the only guy.
I hated the cable "heat stretch" that changed engagement feel depending upon temperature, especially in hot stop/go traffic. With the hydraulic clutch that never happens.
Old Mar 4, 2021 | 04:22 PM
  #33
pyuchem's Avatar
pyuchem
My 2016 SGS hydraulic clutch feels nice and firm first thing starting in the morning and then it's whacky after the bike's hot. The engagement point is not at the same spot and feels like there's no friction zone. Whatever friction zone there is, it's so little. It's not like Jap bikes that I'm used to or other cable clutch that I've used.
SO I'm curious to see how this cable clutch is. Although I read someplace that even Harley going back to cable clutch pull is still very stiff and not light.
Old Mar 4, 2021 | 05:16 PM
  #34
handirifle's Avatar
handirifle
Well I want to test a new model to see for my self. I know the sportsters cable clutch was grabby but that might have been mine. Although on the Ride Like a Pro DVD he comments that the sportsters factory clutch is not ideal for low speed work because of that
One of bis youtube videos was how I came to learn HD had switched back. He was thrilled. It will be a couple weeks before I can get down to the dealer to test one though. Got an RV trip coming up.
Old Mar 5, 2021 | 07:37 AM
  #35
Firenailer's Avatar
Firenailer
I guess everybody has their own opinions, but I’ve gotta be honest I REALLY like the feel of the cable clutch on my new ‘21. I really didn’t mind the hydraulic feel on my ‘17, but It’s really nice to have an old time feeling friction zone again.
Old Mar 5, 2021 | 08:35 AM
  #36
pyuchem's Avatar
pyuchem
hows the pull effort ? Like I said in my earlier post, with my 2016 SGS I don’t feel any friction zone or whatever there is, it’s so little as if non existent. So I’m glad to hear that there’s some friction zone with cable.
Old Mar 5, 2021 | 12:36 PM
  #37
handirifle's Avatar
handirifle
My 14 is the same way, its more like a light switch, its either engaged or not. VERY hard to regulate. I have small hands (size med in most gloves) so the shorter fingers might have something to do with this, but this friction zone is almost non existent.
Old Mar 5, 2021 | 07:40 PM
  #38
pyuchem's Avatar
pyuchem
I meant How's the pull effort on newer cable clutch ? For some reason I thought you test rode this new bike.
Yeah I know what you mean by friction zone non existent on hydraulic clutch bike. I have 2016 SGS and I struggle with this.
Old Mar 5, 2021 | 09:50 PM
  #39
handirifle's Avatar
handirifle
I think your question was for firenailer. I won't be able to test one for at least a week.
Old Mar 6, 2021 | 07:12 AM
  #40
Sol-Invictus's Avatar
Sol-Invictus
I tried several 21s with the cable including 2 CVOs. Without question the cable is a much heavier pull than my 2020 and if you have to pull the lever all the way to the bar, that will suck.
The correct way to use a hydro is with 2 or 3 fingers on the grip and then use 1 or 2 to activate. You will immediately notice a much better feel, smoother engagement, a more useful friction zone etc. If you are pulling it to the bar you are using it wrong. The MSF needs to update their training. Even FINE-C is outdated, no petcocks to turn on and no choke on any modern street bike. They need to teach proper technique and shame on Harley for not telling riders that one of the advantages of hydro is you don't have to pull all the way to the bar, but use your most sensitive finger or fingers for actuation.
We have been using them for racing for the last 10 years. There is no way I will ever go back to a scratchy, inconsistent, canyon wide, useless for precision friction zone that requires constant adjustment during a 2 hour race, and worse makes you take all your fingers off the grip to use, let one an all day ride. There is a reason no modern bikes of consequence use them anymore.
If you are going to make people deal with outdated tech like that at least give them and adjuster wheel by the lever so they can take up the fade during a ride. Lol.
An adjustable lever or a new slave are cheaper than a good helmet if you have smaller hands or less strength.
Good thing I have a 2020 because I will NEVER buy a new street bike with a cable clutch, carb, kick start, points, tubed tires, non abs or traction control, cruise control, drum brakes or chain ever again.
