Primary chain tensioner
Old Jul 12, 2021 | 09:05 AM
twincam10353's Avatar
twincam10353
Default Primary chain tensioner
What's everybody running for a primary chain tensioner? I have to remove my primary cover for a separate issue soon and considering replacing my OEM tensioner while I'm in there. I'm looking at the Baker manual-style one now.
Old Jul 12, 2021 | 09:18 AM
Steve Helton 2's Avatar
Steve Helton 2
I use the hayden no problems so far.
Old Jul 12, 2021 | 09:29 AM
twincam10353
The Hayden is an "automatic" style tensioner just like the OEM unit, correct? I think I'd rather go with a manual type unit so there's no way of the chain over-tightening itself.
Old Jul 12, 2021 | 10:14 AM
Steve Helton 2
It flexes up and down has springs under the shoe it don't tighten up like the oem manual would be a good one too.
Old Jul 12, 2021 | 10:53 AM
hardheaded's Avatar
hardheaded
I've had the baker since 2012 and it seems to be fine. Less noise in the primary after i installed it and got it run in.
Old Jul 12, 2021 | 11:19 AM
Screamin beagle's Avatar
Screamin beagle
Another vote for the Hayden. Eliminated alot of the first gear clunk. Great price too...you can buy alot of beer and gas with money you saved not buying a baker...nothing wrong with them other than that price tag. Only word of caution if you use the Hayden is make sure you put the shoe on the right way.
Old Jul 12, 2021 | 11:45 AM
hattitude's Avatar
hattitude
What year is your bike and what issues are you having.....??
FWIW... the first primary auto tensioner debuted on a few models in 2006, and was OEM across the line in 2007... That version was problematic (#39929-06A). It caused the primary chain to overtighten, and that caused other related issues.
In 2010, HD upgraded the primary auto tensioner to #39929-06B. Since that upgrade, it has been far less problematic. Just don't do hard downshifts until the primary is up to temp and in most cases it doesn't over tighten the primary change.
I used the #39929-06B OEM tensioner in my 2016 Bagger with a 124" S&S engine (135HP & 151TQ) and it worked just fine...
The newer version has a beefier frame for less flex, smaller teeth and less teeth on one of the ramps to allow for smaller incremental changes, and one or two other things I can't remember..
Here is a pic of the two different auto tensioners. the new "B: version is on top. You can see it's a better built tensioner..
Old Jul 12, 2021 | 12:56 PM
twincam10353
Thanks for all that information. I'm riding a 2016 FHXS coming up on 23k miles. No issues yet. I'll be opening up the primary to JB Weld a small hairline crack and figured I could do some upgrading if worthy while having the primary opened up.
Old Jul 12, 2021 | 08:04 PM
GalvTexGuy's Avatar
GalvTexGuy
On my ‘14 Limited, I replaced the original at around 45K. The original was not over tight when I inspected it before removing it. Wear on the shoe was, I think, normal for that mileage. I would have felt comfortable putting more miles on it. I went back with another new OEM.
Old Jul 12, 2021 | 08:08 PM
sanman4ever's Avatar
sanman4ever
I have the baker. They recommend a 5k inspection and when I did mine it looked brand new and no adjustment was needed.
