Clutch cable
Old Jan 12, 2023 | 04:13 PM
hdwd2000's Avatar
hdwd2000
Default Clutch cable
Anybody having problems with their clutch cable breaking? I have a 21 road glide.
Thanks
Old Jan 12, 2023 | 06:27 PM
pswomack's Avatar
pswomack
Thanks
The 2021 Road Glide has a hydraulic clutch, so no cable to worry about breaking.
Old Jan 12, 2023 | 06:37 PM
Red's Avatar
Red
2021 Touring models have clutch cables. They aren't hydraulic
The cable on my '21 Limited needs to be replaced at 28,000 miles. It's stretched with no more adjustment available. Hasn't broken yet!
Old Jan 12, 2023 | 08:34 PM
MRFREEZE57's Avatar
MRFREEZE57
I have 30k on my 21 Limited, still has plenty of adjustment, although I replaced that goofy plastic adjuster with a Fat Baggers easy adjuster.
Old Jan 13, 2023 | 04:59 PM
harleydude-fla's Avatar
harleydude-fla
Have you made the adjustment at the clutch pack behind the primary cover yet?
Old Jan 13, 2023 | 05:05 PM
pswomack's Avatar
pswomack
Thanks for the info, I didn't know that HD went back to a cable for the clutch.
Old Jan 13, 2023 | 05:07 PM
Red's Avatar
Red
Yes a few times. I can only back it off about 1/4 turn. If I back it off 1/2 to 1 full turn the clutch won't release correctly.
The adjustment on the cable is on the last threaded groove.
Old Jan 15, 2023 | 07:15 PM
Hawg Runner's Avatar
Hawg Runner
Sounds like time to to Barnett.
Old Jan 16, 2023 | 11:53 PM
Axedude's Avatar
Axedude
I’ve been thinking about buying the Fat Baggers EZ clutch adjuster but I wonder what the purpose of the spring is on factory adjuster.
I adjusted my mine to get the friction zone closer to the grip. I have the click that’s been mentioned before. I’m not sure if it started after that or not.
I can’t find much on reviews of the FBI adjuster other than what was mentioned in this thread.
The guys at the dealer haven’t even heard about it. This seems like a weak point on the new bikes.
Old Jan 17, 2023 | 09:59 AM
MRFREEZE57's Avatar
MRFREEZE57
You just remove the spring when installing the EZ adjuster, took me about 30 min to install it, you also have much more accurate clutch adjustment with it. The big reason I installed one was hearing some having the plastic adjuster break.
