Can’t tighten chain
Old Dec 6, 2023 | 09:10 PM
Joe0328's Avatar
Joe0328
Stage IV
Default Can’t tighten chain
I have a 2015 road king and I did the Trask chain conversion with 530 chain 120t, I can’t seem to adjust the rear tire to get the chain tight and I did already remove a link in the chain, idk what I’m missing, do I gotta change the rear axle or something??
Old Dec 6, 2023 | 10:43 PM
TwiZted Biker's Avatar
TwiZted Biker
Can't take a full link they do make 1/2's, that or sprockets.
Old Dec 7, 2023 | 09:41 AM
btsom's Avatar
btsom
How many miles on this set-up? Sprockets wear and eventually need to be replaced.
Old Dec 7, 2023 | 09:50 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Wrong chain length? Probably worth measuring/counting yours and contacting Trask about what you’ve got vs what it’s supposed to be.
Old Dec 7, 2023 | 12:42 PM
KK0G's Avatar
KK0G
If the axle is bottomed out and the chain isn't tight then clearly it's still too long.
Old Dec 7, 2023 | 01:21 PM
Redrodyankneck's Avatar
Redrodyankneck
Don't over think it.. Since you already removed a link, why not remove another? What do you mean changing the rear axle? You mean the diameter, cut the chain until it fits. I have purchased many 120 chains for a 108 link spec
Old Dec 7, 2023 | 07:55 PM
Max Headflow's Avatar
Max Headflow
Because with the cam adjusters there may not be enough slack? The tension system is setup for a belt with fixed pulley sizes.
With a 5/8 pitch chain, removing 1 full link will require moving the axle forward about 5/8 inch.. Is there enough adjustment? Might be better off welding a 1/4 inch block on the stop that the cams rest against or going to one of those fancy axle/adjusters..
cbacon1788
May 3, 2018 10:17 AM
Ston
Shovelhead
Jul 3, 2017 05:22 PM
glidein wide
Feb 5, 2015 06:17 PM
heavyp36
May 5, 2012 09:54 AM
jtmon75
Ironhead
11
Mar 18, 2011 01:36 PM
