Ive learned to ignore your posts. Its too bad the Ignore function on the site still shows that a post was made. Oh well.
Because you cant answer a valid question? No wonder you dont know what is not a problem if you run floating rotors or not. Maybe you should learn to read answers. Will help a lot more than whining like a Mitch. I wont be losing any sleep.
Good luck in your quest to only hear what you want to hear.
Since we're talking about this, I wonder, and have in the past, about the function of the rubber insert/plug, #5, that is installed onto the bracket, #9, in the diagram and whether or not it allows MINIMAL movement at the point where the bracket mounts onto the weldment piece of the swingarm. I know the part of the bracket that has the axle running through it is stationary and keeps any lateral movement, left/right, from happening when the axle nut is torqued down, but is that rubber piece there to allow slight rotational movement? Just curious as to its function. Does it qualify it as a "Floating Caliper"?
It seems to me that it's just an anti-rattle rubber bumper.
Maybe. Good possibility...........
But it could only rattle if there was some sort of movement, I would think?
I just looked at mine. The caliper hard mounts to the bracket. 2 bolts, metal to metal. No float there. The caliper while a different PN then the fronts which hard mount to the slider, doesn't appear to be any different functionally then the fronts. i.e. no internal "floating" mechanism. The rear side of the caliper bracket has a ring which slips over the axle, and a u channel on the front which slides over a rail cast into the swingarm. I guess that's to allow for forward to rear movement when adjusting the belt tension. That rubber biscuit prevents rattle as you say I expect.
The rear of the bracket is clamped against the ABS Sensor/spacer and then the inner bearing race when the axle is torqued down. No movement there.
So I see no floating functionality on the rear caliper, unless I'm missing something. Which is odd since I thought you wanted ONE of the two components to float - Rotor or caliper. I guess not needed on the rear wheel?
Sorry I missed this when I basically repeated everything you just said!
I thought "floating" means the caliper can move laterally, not radially. So I still don't see that anywhere on the rear brake.
Pretty sure the rear caliper is a 4 piston caliper ( pistons move on both inboard and outboard ) therefore providing egual pressure to both the inboard and outboard brake pads when the system is energized hence the need for no movement by the caliper
But, you just brought up an excellent point that I didn't think of! Bracket #9 is probably designed like that so slide fore/aft for belt tensioning! Makes perfect sense and I can sleep now, thank you, lol!
Right, but so are the fronts. They why use floating rotors on one end and not the other. This doesn't matter anymore since I just moved the stock fixed rotor to the new wheel, but just for discussions sake?
