Starter repeatedly clicks, doesn’t turn over engine
Old May 19, 2024 | 10:19 AM
Jackie Paper's Avatar
Jackie Paper
When I see 12.9 from people, it tells me they are checking battery with a surface charge on it from the charger. Alway take your battery reading after turning on light for a minute and then everything off. Then check.
(A maintenance charger puts out about 13.5 or so to charge. It leaves a surface charge until that is pulled off with a load or letting battery normalize a few hours)
I am reading a lot of confusing about is starter running or not.
Your 12.5 probably is your actual battery condition. A little low for a new battery if it's been given a good 24 hours on a maintenance charger.
You either still have a battery issue, cable issues, or a starter issues.
I would address problem in that order.
Ballpark battery is 12.7. A 12.3 is just about discharged. Once you actually get it cranking, it should not drop below 9.7 on a stock motor.
Old May 19, 2024 | 10:25 AM
Rounders's Avatar
Rounders
Originally Posted by Jesseppers
I used my battery chargers Jump feature to try to start it, this sends 50 amps to the battery. No difference when I tried this.
Well than probably not battery. Check ground as said, but I have never had a bad one, but many have. Any value in putting meter on metal and + on battery and seeing what it reads, compared to across battery? This may not work, since it only needs a little bit a connection for meter. But free to do.
How many miles on starter?
In my experience, starter clutches kick back when bad. I have never done it, but some people talk about pushing solenoid in. Ya starters are expensive!!
Old May 19, 2024 | 11:15 AM
Ultra103's Avatar
Ultra103
No idea what the issue is since I observe a strict order of operations during diagnostics. A couple of points, however. Be careful applying outside power, it's easy to hurt computers. If the battery is good, the cables aren't showing an appreciable resistance and are clean at both ends and directly jumping the starter solenoid has the same effect as pressing the start button, the starter is likely bad.
Assuming you cleaned / replaced the copper contacts in the solenoid and plunger and that the starter was correctly reassebled, the repeated clicking would indicate a lack of incoming power.
Old May 19, 2024 | 02:50 PM
HeritageBrads's Avatar
HeritageBrads
9 times out of 10 this is the battery .
try a booster pack on it and see what happens
Old May 19, 2024 | 04:06 PM
Max Headflow's Avatar
Max Headflow
AGMs that are brand new will read that.. Even right out of the box.. Obviously with the lights on it will be lower..
Old May 19, 2024 | 05:37 PM
Jackie Paper
Not the last 4 I have had. And that also is out of Harley OEM service manual.
And I never said to check with lights on if you are referring to me.
Help the first poster. You want to make statements to him, fine, whatever you like to say, I am fine with.
Old May 19, 2024 | 06:00 PM
Max Headflow
The last 4 Yuasa AGM I had read 12.9 out of the box and the same a few days later. GYZ30HL and GYZ20H(L) They also read 10-20% above the rated CCA.
Old May 19, 2024 | 07:23 PM
Jackie Paper
Didn't say I didn't believe you. And why I said
'Help the first poster. You want to make statements to him, fine, whatever you like to say, I am fine with.
It just not what I have seen.
And yes I have read what you are saying and how to propercharge a AGM..
Remember also up there, I ask and talked about making sure he wasn't reading some of the charging voltage and to make sure of it.
Just trying to rule a good or bad issue from text is pretty difficult.
Old May 19, 2024 | 08:33 PM
Max Headflow
While it sounded like you didn't believe the value the OP saw..
Old May 19, 2024 | 09:02 PM
Jesseppers's Avatar
Jesseppers
6th Gear
Disregard. I don’t know how to delete my reply.
