Help! New to me 2007 Electra Glide Brakes
Old Jul 15, 2024 | 12:58 PM
slharman1's Avatar
slharman1
Default Help! New to me 2007 Electra Glide Brakes
Well,
I didn't even make it home from the guys house I bought the bike from and the front brakes seized up. Front end went squirrely aid laid it down at 20 mph.
Not only did I scratch my new to me bike but I had to open the front caliper bleeders to make it home.
My question is What the heck could make the front lock up like that?
I haven't even got it inspected or registered ye but now need to fix first.
Any help would be greatly appreciated.
Thanks
A Newbie
Old Jul 15, 2024 | 03:39 PM
Ultra103's Avatar
Ultra103
ABS unit most likely, if equipped. If not, check the front caliper and the front hoses. The hoses sometimes collapse and hold pressure on the caliper.
Old Jul 15, 2024 | 03:48 PM
slharman1's Avatar
slharman1
2007 Electra Glide FLHT, no abs and uses DOT4.
Is there a way to check the hoses,
I read another post that says if loosening bleed screws release the pads then calipers are working fine, sounds right to me.
So now I am looking at 3 little holes in the bottom of the reservoir, Two side by side and one on the other side of the bottom.
Only the single hole looks to be returning fluid when releasing the brake lever.
What are the other two holes, I can only assume they are the supply ports to each caliper.
Again is there a test for the hoses - I don't need any more scratches on this thing.
Old Nov 11, 2024 | 11:06 AM
GoofySB's Avatar
GoofySB
I realize you posted about 4 months ago, but for you or others. Check the caliper pistons for corrosion and replace any rubber parts in piston cavity. I had a similar issue in 2008.
slharman1
Jul 16, 2024 10:48 AM
sgtcole69
Dec 31, 2017 06:39 PM
krustydude
Jun 7, 2010 04:08 PM
eddieflyer
Sep 9, 2007 05:00 PM
