Suspension options for a 2018 Ultra Limited
Old Dec 1, 2024 | 12:56 PM
tderksen1971's Avatar
tderksen1971
Default Suspension options for a 2018 Ultra Limited
I have a 2018 Ultra with 97,000Kms on it. (around 60,000 miles). I purchased it this summer (2024) and I suspect that the fork seals/oil have never been changed. So I am going to do that this winter.
Most of the threads I see on here are several years old, so with all the new technology, I am posting a new thread. I am considering upgrading the suspension at the same time and have been looking at posts here to make the best overall decision with the most information before making a purchase. I have never upgraded the suspension on any of my bikes, and this is certainly one of my least knowledgeable areas.
I have looked at Progressive, Ohlins, and now Legend. From what I see, I don't like that Legend has the preload inside the fork. In order to adjust it, you have to take the fork apart. Ohlins definately seems to be the better setup in that regard. For any of the 'performance' upgrades, I am looking at $2000 just to do the front suspension. (That's if I go with front shocks that have the internal gas preload)
However, since I have never even tried upgrading the suspension, is a progressive suspension standard spring good enough for me? I can get the Harley setup here for $250 CAD.
I have also started looking at the rear suspension, and am faced with the same dilemma. I am not a fan of the 'look' of the suspension with the external reservoir, but having adjustability over both rear shocks to change from when I am riding solo in "Street Glide mode" vs two up with the tour pack seems to make sense. To be honest, I haven't even figured out how to dial in the stock rear suspension.
So if you all have advice, I'm all ears.
Old Dec 1, 2024 | 03:34 PM
Black Ultra's Avatar
Black Ultra
On any Batwing, you won't be able to get to the adjustment on any fork cartridge without moving the fairing out to the way first. So, keep that in mind when looking at anything adjustable up front. I would look at the Pro-Action front fork kits and their rear shocks as well. I have them both and really like them. Nothing up front to adjust, so it doesn't matter that you can't easily get to the top of the forks. The rears are easy to adjust, but like any others, the bags have to come off to adjust.
Old Dec 1, 2024 | 03:44 PM
Ultra103's Avatar
Ultra103
With that mileage, rebuilding the factory forks will make a big difference. It's hard to notice degradation over time but I rebuilt mine at 50,000 miles while I was putting chrome lowers on and holy moley it made a nice difference. I'm not one who needs fancy suspension or engine upgrades, the bike gets me to work and back daily and wherever I want to go in between but it felt 'new' again. The biggest difference was how it eats potholes and washboard so much better now.
I did add a little more viscosity in the replacement fluid on the recommendation of a mechanic buddy but I don't know how much difference it would have made.
Old Dec 2, 2024 | 05:01 AM
Slingshot383's Avatar
Slingshot383
Another place to look is CK Products, they carry an array of shocks, and the Gold Valve Intimidators for the front forks. Yes, you can get fork springs that match your weight and riding style, and change the weight of the fork oil, all of which help make the suspension dialed in to you.
Old Dec 2, 2024 | 07:31 AM
SSG_B's Avatar
SSG_B
I have an 18UL and did the ProAction up front and have the Ohlins HD 044 in the rear. The PA is a huge inprovement over stock but I will be changing out to the Ohlins cartridges in the front at some point. More adjustment options.
Old Dec 2, 2024 | 10:08 AM
MRFREEZE57's Avatar
MRFREEZE57
This here. I did a fork rebuild on the RGL at 46k miles, that oil looked like had been run in a diesel truck for a half million miles. The rebuild kit which included bushings and seals for both forks was about 75 bucks, refilled with Amsoil shock therapy #10 suspension fluid, with a rebuild and good quality oil the factory set up while not like an expensive set of cartridges is actually pretty decent.
Old Dec 3, 2024 | 01:54 PM
MRFREEZE57's Avatar
MRFREEZE57
Originally Posted by Badger&Boar
100% Even just you changing out the oil your self, doing a brief flush/drain with fresh fluids, you'll see a HUGE difference. IIRC, you can do about the same your self with the rear end as well; change the oil.
Have never looked into it but I do not think that the factory rear shocks on the 2021 models are serviceable.
Old Dec 3, 2024 | 01:59 PM
NorthWestern's Avatar
NorthWestern
Weird, there are actually several threads on suspension, and they would be worth you looking at. It is one of the more common subjects/upgrades for the Touring crowd.
As for the reservoirs showing, I don't like that either, and you can absolutely HIDE the Ohlins HD044 reservoirs with the supplied clamps. That is what I did.
Ohlins cartridges up front is all that I can recommend, I do love mine.
Best of luck, it is so very worth it!
Old Dec 3, 2024 | 03:42 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
There's an ample amount of options out there to compare when addressing this.
Which makes Doing It Right the First Time all the more important.
We have spent years testing Rear Shock Performance and listing all of our findings in our report, which you may find helpful in making your decision.
When addressing the Front Suspension, we have also collected some great data on this over the years you might consider.
Feel free to give us a call or shoot us an email with any questions you may have.
Ride Safe, Ride Free.
Shelly
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Dec 3, 2024 | 03:48 PM
Goose_NC's Avatar
Goose_NC
K, but the OP is working on a 2018. Are you in the right thread?
Stock 2018 shocks are also not able to be rebuilt, according to HD.
