I picked up their entry level upgrade as it was on sale recently. Total, delivered was $530. I spent bout 2.5hrs taking my time installing it all this afternoon.
this truly is a plug and play. All I wanted was something better than stock, on a budget. This nailed it. Im not an audio guy, but I can say theres no distortion and it is much louder and clear.
Nothing is visible either. Under the seat, cant see anything. I left the stock Special grilles as well.
definitely happy with it and again, the install is a snap. Just have a swivel socket
Not sure what model that is but I was looking at P HD1F Kenwood about that price line for my bike. I don't have the courage to take that speaker pod out, could they have made it any harder? I don't like running new wires either, do you have to pull tank and run new wires to battery? Thanks
was just telling a friend how simple it was. Yes, the tank comes off. 4 bolts, quick disconnect, a vent and plug. The speaker pod bolt terror is unfounded. A simple swivel socket makes it very easy.
knowing what a shop would charge in labor, i can absolutely see its main competitor is the Rockford Fosgate upgrade from HD, but less than half the price. But this is simply the front speakers with a small amp.
I left the stock grilles on because they’re “upgraded” on the Special. Even if you pulled the seat off, you wouldn’t see anything indicating it’s there. The power/ground is run along the backbone, along with the factory rats nest of wiring. But you don’t splice anything. It’s all plugs. It’s that simple, compact and easy to do.
