Android Auto
Old Jul 17, 2025 | 07:46 AM
Uncle Larry's Avatar
Uncle Larry
Do you know Rounders ?
Old Jul 17, 2025 | 11:13 AM
Punkin49's Avatar
Punkin49
Samsung S25 Ultra. At one point it would disconnect every hard bump. I replaced the cable from the back of the radio to the pocket. I had replaced the cable from pocket to phone. Still had some issues.
I eventually got the right combo of radio cords and phone cords to not make it disconnect on bumps. I did also bend/pinch/make the end of the usb-c port that goes into my phone a little so it would be harder to plug into the phone and stay in the phone harder. if that makes sense.
I've just learned to plug in the phone after i turn the key on, I've also learned to turn the bike to accessory mode when at a fuel stop so i don't have to unplug and plug the phone back in every time.
Old Jul 19, 2025 | 01:24 PM
timbo141's Avatar
timbo141
Originally Posted by Punkin49
Samsung S25 Ultra. I've just learned to plug in the phone after i turn the key on, I've also learned to turn the bike to accessory mode when at a fuel stop so i don't have to unplug and plug the phone back in every time.
See, first reply in this thread works. No joke.
Sometimes you just have to do what works.
I also have been turning bike on accessory mode at gas stops and most short under 15 minute stops for 10 years on my 2015 RGS, both 6.5 and GTS radios. (In accessory mode the security will disable the ignition)
For wireless AA I use aawireless2 dongle. Works great with GTS radio.
Old Jul 19, 2025 | 06:40 PM
hattitude's Avatar
hattitude
GalvTexGuy and Uncle Larry, thanks for the kind words...
Probably not my best joke, but being Android Auto impaired, I was also trying to tongue-in-cheek imply that since it's been happening before & after an update, it might be working as designed...
The poster who said it may be his personal phone settings, in retrospect, is probably closer to the solution...
IMHO, the OP is way too thin skinned, and a bit self absorbed, to think we are here at his beck & call and somehow limited based on what he wants.
I blocked him so I won't have to see, read, or deal with his tantrums in the future.
Peace out....
Old Jul 19, 2025 | 09:38 PM
user 37373838's Avatar
user 37373838
Peace out....
You are something... First you know nothing of me or where I come from. This forum is for connecting with other and helping when and if needed. I'm all for the jokes and I have many. Block me if you want I don't care. But if others are getting butt hurt because I called them out so be it. I'm far from thin skin. No you are not here to wait on my needs. I was just asking for a little knowledge from someone that may have ran into my situation. Thank you for your time and have a great day. I know I will
Old Jul 20, 2025 | 07:16 AM
cycle7447's Avatar
cycle7447
Community Influencer
OP - lots of folks here are very helpful. I have sort of learned to accept the help from those that try - and also provide help when I can. I would hope that you will continue to offer help on those topics that you can.
OK, back to your issue. Since you shared that your setting were correct, let's go a different way. Sounds like your phone is connected directly to the cable in the cubby.
Several of us use a wireless connector and keep our phones in our pockets or the trunk. That wireless connector comes on as soon as you turn the key on. So, this would be like you're plugging the phone in after your turn the bike on.
I have tried several of these - all have worked. My first was the Motorla MA1 connector $49.96). I have also tried the Air2 Ottocast ($55) and the MSXTTLY ($37.99). I have the MA1 on the bike and use the others on my vehicles. When I got a new truck, that was already wireless - so I put that in the bike as a backup.
When travelling and folks ask how I connect, I often connect their bike with my backup, let them use it on a trip - and then they buy one when we get back. I think you will find there are a number of advantages to these connectors.
So, why not get one from Amazon. Hook it up and see how it works. If that solves the issue, then keep it. If not, well, you have 30 days to return it. Try the MAI - go to the bike, turn it on before you get on the bike, put your phone it your pocket - jump on the bike - and by that time the MA1 should connect, and you are all set.
Let us know how this works.
Old Jul 20, 2025 | 02:03 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Active Streak: 30 Days
I use AA Wireless dongle on both bikes. Actually I only have one and plug it into which ever bike I am riding. Simple, almost instantly connects and in the rare occasion it doesn’t just go to the app and fix it easily.
My Phone would barely fit into the cuddy storage compartment on the RG and SG. It would always come unplugged on the RG with the slightest bump in the road.
Problem solved, using it for almost two years now.
Old Jul 20, 2025 | 02:06 PM
Rounders's Avatar
Rounders
My truck, I just get in and sit down.
Old Jul 20, 2025 | 02:47 PM
Cosmic Razorback
Yeah, it’s got to be tough when you have to be driven by others.
Get in, sit down and shut up.
Old Jul 20, 2025 | 11:17 PM
Rounders's Avatar
Rounders
Huh? I mean really, huh? Try to put some thought into it I realize you are so upset you are peeing yourself when you see I posted. But wait, clean yourself, and try to come up with something, Though I have my doubts you have the ability.
To bad harley can't figure out GM figured out years ago for Bluetooth. On bike I tend to USB more, rather than spend the time with blue tooth. I want to get on bike and go, just like my truck, get in and go.
