GPS Help: Not routing correctly
Old Apr 4, 2014 | 08:22 AM
HDReiter's Avatar
HDReiter
Default GPS Help: Not routing correctly
I used the HD Ride Planner for a trip to the Texas Hill Country yesterday. I had no problem saving the trip and importing the file to the GPS system.
I checked avoid highways and moved/dragged the road once which I believe created one way point between the start and destination. When I got on the road, the GPS wants to take me to the highway. I always carry a map and was able to make my destination yesterday. Is there any reason why the GPS is not following my saved Ride Planner trip?
In addition, I am only seeing one white dot on the Ride Planner map between the start and destination.
Old Apr 4, 2014 | 08:40 AM
hojones's Avatar
hojones
If you are accustomed to using a garmin, this gps HD has sold us is very inferior.
Old Apr 4, 2014 | 09:21 AM
MikeyTX's Avatar
MikeyTX
Understatement of the year ........ It's mainly for those that like touring various MoCo dealerships by interstate or four lane divided U S highways. I use google maps on my cell phone when need be. Otherwise I rely on a printed map
Old Apr 4, 2014 | 10:24 AM
ChristoHD's Avatar
ChristoHD
This is not good if the HD system is not recognizing the waypoints for route modification. HD's own literature states that you can't have any more than 9 in any given A-B route/leg.
What a cool feature would be in the 6.5 HD Bike GPS was a route preview/ride, so you can confirm that your route modifications were accounted for on the export/import. I know you can see an overview if you back the bikes GPS map view to the neg and widen out to see the route.
I will do a quick test and see if the WP's are even being recognized from the HD RP.
Back in a few with my findings.
Old Apr 4, 2014 | 10:53 AM
ChristoHD's Avatar
ChristoHD
Ok I just did the test...
I had a point A to point B. The HD RidePlanner for this route chose to take the toll road between these 2 points, so I used 2 waypoint to take another straight route on a hwy instead.
I then saved the ride to my Desktop. Called it Test1.GPX. Copied that to my USB drive.
Turned on 6.5, went to the import screen, select the file you just created, it shows me a list; the route name trip and of course my starting place and ending place, so three things in the list.
Select the route ONLY, and import.
Now you go to your destination set on the Nav system, where to, more, select trips - you will then be shown another list which has start, Point A, waypoint1, waypoint2, Point B...
SELECT START - and it will calculate the route with your waypoints.
My GPS settings were: avoid/use hwys, avoid/use tolls, fastest, shortest, scenic, etc. - I tried them all.
But my map held true to the route designed using my 2 waypoints to change the course it would try and do by default.
I think what most people make the mistake is when after you select the "trips" button, which then takes you to where your stored routes are, and you select your trip, some have selected the last end point and then set as new destination so the bike's GPS is just calculating to that final destination on it's own thereby ignoring your entire route.
So make sure you use the start button and it should work.
Also at this point where you see the start button and the list of places, you can verify right then and there if your waypoints are in that route. Just make sure you scroll back to the start button and select start. :-)
HTH
Old Apr 4, 2014 | 06:08 PM
HDReiter's Avatar
HDReiter
I think the issue is all on me because I wasn't selecting trips option. I was selecting the saved option. I'll give it a test on the way back home.
Thanks for the help!
Old Apr 5, 2014 | 02:34 AM
WildThang's Avatar
WildThang
Originally Posted by ChristoHD
I think what most people make the mistake of is when after you select the "trips" button, which then takes you to where your stored routes are, and you select your trip, some have selected the end point B and then set as new destination so the bike's GPS is just calculating to that final destination on it's own thereby ignoring your entire route.
HTH
Bingo...as I forgot to do this very thing some time ago....
FWI, according to a very reliable source, the 9 waypoint limit and a few other things (don't want to spoil the suprise) will be updated in the near future. As with just about any software/firmware on the planet Earth, never fully functional out of the gate....takes revisions to get it to mature. Show m3 any software that stay at version 1.0/build 1
Old Apr 5, 2014 | 05:42 PM
hogowner69's Avatar
hogowner69
don't want to spoil the surprise??? Why not?
Old Apr 5, 2014 | 05:57 PM
IUOE ROB's Avatar
IUOE ROB
Spoil away!
Old Apr 6, 2014 | 02:10 AM
Custardglide's Avatar
Custardglide
C'MON SPILL THE BEANZ!!!
It means I can stop saving up for my 2019 limited with GARMIN fitted as standard along with rear shocks that work, oh and the 120R engine
