EITMS - Engine Idle Temperature Management System
Old May 1, 2014 | 09:15 AM
Harttoo's Avatar
Harttoo
Originally Posted by Bagged Out
Agree with the sound and smell but it ONLY activates at idle. It kicks off as soon as you give it the gas.
Doesn't kick off fast enough for Me.I may have a heavy hand.lol.
Old May 3, 2014 | 11:19 PM
Webo's Avatar
Webo
I blip the throttle before I start to take off so it disengages before I take off.
Old May 4, 2014 | 12:46 AM
TexasMotorcycleRider's Avatar
Mine is kicking on regular now and no hesitating when I take off. Doesn't seem to be too much heat from the engine either.
Old May 4, 2014 | 01:42 AM
Sam2010's Avatar
Sam2010
The system works better than it did in 2010. I also think if water cooling heads is valid then you could argue air cooling heads with fans is. IMO.
Old May 4, 2014 | 12:20 PM
offthewall's Avatar
offthewall
I think some of that may be psychological. LOL
I just tried to find the specs again and failed but I recall it being in the ms range. I can't see how you could really feel that.
Admittedly, it's only kicked in for me a few times. Temps still in the 50's and 60's here in NJ. It does take you by surprise the first time since it sounds like something is very wrong with the engine idle.
Old May 4, 2014 | 09:34 PM
2NAHNTR's Avatar
2NAHNTR
I rode to Panama City Beach this weekend for the Thunderbeach Rally. The system came on every time I stopped at a light during the hot days. Temps were in the 80's. Like Webo, I blip the throttle to cut if off before I let out the clutch. If I didn't, sometimes it would burp and almost stall. It took me a little while to figure out that it was the EITMS that was causing it. I thought something was wrong with the bike at first. You can definitely tell when it activates. RPMs go down a touch and it vibrates. I never really smelled anything different.
Old May 5, 2014 | 08:57 AM
jcapps's Avatar
jcapps
Mine is almost unnoticeable when it enters the mode and equally seamless as I take off
Old Jul 26, 2014 | 02:01 PM
aje802's Avatar
aje802
6th Gear
Originally Posted by dpmerrill
I've used the info screen to show when it was enabled or disabled, but I didn't know it would show when it is actually active. Pretty cool. I'll have to watch for that.
I know what you mean about taking their word for it that EITMS is a good thing. Luckily they turn off the fuel injector when EITMS kicks in so we're not soaking plugs, but I keep remembering all the problems GM had with their 8-6-4 experiment. Multi-displacement is old news nowdays, but it still seems weird to shut down a cylinder in a running engine.
Great shot of Garden of the Gods (as if there's a bad shot). Also... what exactly causes the rear jug to "shut down?"
Fuel cuts off, spark cust off, both?
A friend of mine told me Dodge Chargers have a similar system, for fuel savings, and not temp management.
Thanks
Old Jul 26, 2014 | 05:31 PM
HD-Gyro's Avatar
HD-Gyro
It shuts off the fuel injector to the rear cylinder.
Old Aug 2, 2014 | 08:54 AM
nevada72's Avatar
nevada72
Question - Why did my dealer deactivate EITMS? Sounds like it's a good thing.
Fwiw, mine is now activated. I must have rolled the throttle forward inadvertently. When it kicks in it sounds different, but I haven't experienced any performance issues so I'm leaving it on.
