EITMS Idle
Old Jul 9, 2014 | 03:41 PM
sixguns's Avatar
sixguns
Originally Posted by Webo
This is why I always blip the throttle when the light turns green before I start to let the clutch out. Let's the system activate the other cylinder before there is a load on the motor.
Me too, see I'm not the only throttle bliper around here.
Old Jul 9, 2014 | 07:22 PM
SafetyMan's Avatar
SafetyMan
Originally Posted by Roger That
I came from a '12 Street Glide to a '12 SGS. What I noticed was that it kicks in a lot sooner than the '12 did. After getting the '12 tuned, I don't think it even came on in the year and a half since. This '14 EITMS kicks on within seconds at a stop.
The old ones relied on ET. The 14s come in based on AT.
Old Jul 9, 2014 | 07:41 PM
sixguns's Avatar
sixguns
check your owners manual, kicks in at 284 degrees, I'm surprised that you missed this one.
Old Jul 9, 2014 | 07:46 PM
RushKing14's Avatar
RushKing14
From the manual
Touring (except FLHR, FLHRC, FLHR CVO FLHRSE AND FLHTCUTG: AAT sensor exceeds 80 degrees F
FLHR, FLHRC, FLHR CVO, FLHP AND FLHTP : ET sensor exceeds 288 F
So Safetyman didn't miss this one, he quoted what his model does.
Old Jul 9, 2014 | 07:58 PM
sixguns's Avatar
sixguns
Originally Posted by mjinks61
Pretty sure that's just for the RKs, some of the 14s kick in 4 seconds after a stop when it is 80+ degrees out. He didn't miss this one, he stated based on his model. it's in the manual and clearly says the differences between the different 14s.
Im quoting the Touring Models 2014 Harley-Davidson owners manual, not sure what your looking at.
Old Jul 9, 2014 | 08:09 PM
RushKing14's Avatar
RushKing14
The information I gave (I edited my original post from where you quoted me for more detail) came out after the manual was printed, as it was misprinted to my understanding.
This information reportedly came straight from the MOCO and EITMS was changed in the 14s from previous years.
And then there's this:
This from HD - TT430: TWIN-COOLED SYSTEM DIAGNOSTICS dated 27 September 2013;
Note that EITMS (rear cylinder cut-out) uses ambient air temperature monitored by the sensor on the left side of the steering head) to activate and deactivate at air temperatures above 80 °F (27 °C). EITMS is completely independent from cooling system operation.
Old Jul 9, 2014 | 08:16 PM
scottt's Avatar
scottt
I turned the system off. Like the feel of both cylinders pumping.
Old Jul 9, 2014 | 08:28 PM
sixguns's Avatar
sixguns
That explains the confusion and miss information. Too bad our MOCO put out bogus info to begin with. SafetyMan, your fine record seems to be intact.
Old Jul 9, 2014 | 08:45 PM
Hammz's Avatar
Hammz
Yes it is! MoCo released the corrected info in Service Bulletin M-1351, dated September 17, 2013. The fact that you were unaware is the fault of your dealer (see attached).
Old Jul 9, 2014 | 09:47 PM
SafetyMan's Avatar
SafetyMan
Thank you sir.
