voice command failure
Old Jul 25, 2014 | 10:49 AM
Pastor Ron's Avatar
Pastor Ron
Default voice command failure
I had something wierd start happening a few weeks ago. When I press the voice command button it beeps and shows the voice command screen momentarily. The screen only stays up a second or so and even if I try to give verbal commands the screen dissapears and nothing happens. Before this started say 3 weeks ago I have had no problems with the system. I took it to my dealer and they said they are working with technical support and waiting for an answer. So has anyone else had this happen?
Old Jul 25, 2014 | 10:54 AM
heritageblue2013's Avatar
heritageblue2013
I don't have that distraction feature on my Heritage.
Old Sep 1, 2014 | 11:19 AM
2WELN's Avatar
2WELN
I am having the same problem with my voice commands. Did you get a fix?
Old Sep 2, 2014 | 01:59 PM
motorcycleboy's Avatar
motorcycleboy
Don't be a Hater.
Old Sep 2, 2014 | 03:41 PM
RevRaz's Avatar
RevRaz
Same thing happens when I talk to my wife, I talk, she doesn't listen
Old Sep 2, 2014 | 05:25 PM
Moe55's Avatar
Moe55
Have the same problem have you heard of a recall or did you get the dealer " they all do that"?
Old Sep 10, 2014 | 07:26 AM
Fishnqueen214's Avatar
Fishnqueen214
I know that the cord in the helmet connection comes loose, mine doe it frequently. Try pushing the connection in an giving a slight turn. You can check this by using the radio through the head set, you can hear a difference.
Old Sep 10, 2014 | 08:16 AM
Harley Hound57's Avatar
Harley Hound57
So there was NO need in you posting in this thread then.
I have not had this problem.
Old Sep 10, 2014 | 02:21 PM
2WELN's Avatar
2WELN
My headset is plugged in good and I am having the same problem. When I press the button on the left handle bar there is a beep, the screen will display a list of options for just a second and it goes away. It doesn't matter if I start speaking as soon as I press the button or not. There is not enough time to make a selection on the screen before it goes away.
sammer4u
2014-2024 Touring Models
33
Jul 21, 2017 09:48 PM
Kayakguy
General Topics/Tech Tips
Jul 28, 2015 07:55 AM
skibum0607
Mar 24, 2015 06:09 PM
coronetracer65
Jun 23, 2014 10:05 AM
jpbo
May 29, 2010 10:32 AM
