Ohlins install help....
Let us know how you make out - I'll be putting my new shocks on tomorrow so will watch this with interest.
Also, what torque spec are you using for the 1/2"-13 bolts?
My shocks look as though they already have some preload on them, did yours come ore-set? In the instructions I have it says they will start out with almost no preload, but I'm wondering if those instructions are out of date.
Checked the sag with wheel off the ground and got 359 mm (r1), bike set back down with no rider 340mm (r2), with me on it 329mm (r3). Howard's site has my shock stroke at 93mm..1/3 of that is 31.
My 359mm minus the 329mm gives me 30mm. I guess I'm right on target and I didn't adjust anything? Damn, Howard is awesome!
Woke up fresh this morning and with the wife sitting on it with me, I threw a saddle bag in the tp and had her hold the other and I had my son measure the sag for us. I had to tighten the collar 13 rounds to get us in the 1/3 stroke spot.
Both the rebound and the compression came at 12 clicks from full closed , during our ride we agreed upon 15 clicks on the rebound and 14 on the compression. I do want to try the zip tie test but it's too dang hot right now.
Oh yeah, the wife hit me up the side of the head and asked why didn't we get these sooner. She said "it's like Butta."
When this is the case and your swing arm is askew it takes some out of the box thinking to get it right.
Adjustable end eyes, like you have:
With the bottom end eye bolted to the swing arm: Loosen the 19mm blue check nut than take a 17mm open end low tirque wrench (thin) and turn (lefty Loosie) the shaft and piston (ya, it turns), threading up the adjustable end eye up into the fixture while holding fast the top end eye/top cap/body/spring from turning. When the bolt is exactly aligned up to the mounting boss/bung so no cross threading will happen, tighten up the top mounting shock bolt, than hold the 17mm hex fixture and tighten up the blue 19mm check nut to lock er' down. Result: the one shock is shorter than the A side (in your case) to make up for the swing arm not being exactly straight with the frame.
Non-Adjustable end eyes:
Fine out which is the (longest) shock and install that one first. Now let down the jack so the second (shorter) shock bolt aligns up with the mounting hole.
I am not telling you what to do. Some men would keep the GPS in the glove compartment and figure out your location and the path on how to get there themselves. I understand that and I told you w had no shock police in your area. Do what you like and what makes you happy. I do not wish to tell you how many of my customers told me their local so called expert "Wrench" could not mount the Ressys on a 2014 bagger. Your install looks very sanitary except for moving the top ressy hose clamp down to the bottom "step/smaller diameter" by drilling the ressy mounting hole closer to the bottom hose clamp as I said earlier this am. If you want people pointing and laughing as you pass by at your askew hose clamps, that is up to you. BTW, that large hole looking from behind is behind the sadle bag and can not be seen.
