2018+ Softail Models Breakout
The Everything 2018+ Heritage Thread
Old Jul 20, 2024 | 09:20 PM
  #3501
skm348's Avatar
skm348
Originally Posted by Rob58
Installed a set of Pazoma shorty levers and they are robust, fit perfect and operate smoothly. Also installed the extended turn signal switches from HD. Really love these two simple upgrades.
Rob58 - which extenders did you buy? When I key in PN …0177 HD Parts says it does NOT fit 2022 HSC 114. Thanks
Old Jul 21, 2024 | 05:18 AM
  #3502
razorbacksrule's Avatar
razorbacksrule
Default Wheels
Originally Posted by WartHoggy
Then that makes two of us. I wish that I had purchased the leftover 22' last year but...
Anyways I feel that I got lucky and was able to purchase a set of take offs now I just need to find the bike
I have cast wheels on mine too if you've ever been stranded on the side of the road with a flat and no way to fix because you had spoke wheels you'll want cast wheels after that .
Old Jul 21, 2024 | 05:52 AM
  #3503
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
My understanding is they do fit just fine on the Heritage.
But, because the left switch doesn't have the symbol for the auxiliary lights, they are listed as not fitting a Heritage.
I bought a set off amazon myself (no real savings btw), but haven't. gotten around to installing them.
Sure looks to be a heck of a lot easier installation than on my 04 RK. That was a bugger of a job.
Old Jul 21, 2024 | 06:04 PM
  #3504
skm348's Avatar
skm348
[QUOTE=foxtrapper;21750577]My understanding is they do fit just fine on the Heritage.
Ah, ok, makes sense, thanks.
Old Jul 22, 2024 | 04:08 PM
  #3505
Uncle G.'s Avatar
Uncle G.
It’s happened to me exactly once in 35 years and over 300,000 miles. Not something I worry about.
The time it did happen was on the way home after a rear tire change. The dealership apparently had a bad batch of inner tubes that split. They had two more tubes fail while trying to repair the tire
Old Jul 23, 2024 | 06:14 AM
  #3506
tmac00333's Avatar
tmac00333
Those levers look really cool. Is that why you got them, for looks, or was there another reason too, like ergonomics or something?
Old Jul 24, 2024 | 12:46 AM
  #3507
BunnoHD's Avatar
BunnoHD
Old Jul 27, 2024 | 05:17 PM
  #3508
Old New Rider's Avatar
Old New Rider
I've got my 2021 Heritage pretty close to what I want, but have been reading about rear shocks.
Stock shock is 'ok', servicable, but wonder if maybe going to a slightly longer shock like Fox 13.5" long might be better / softer? Ohlins too short, Progressives close.
If I adjust the stock shock too high it rides harsh an jittery. Too soft and it bottoms over edges and train tracks.
Is this the right thread for this question?
Old Jul 27, 2024 | 05:55 PM
  #3509
foxtrapper's Avatar
foxtrapper
Originally Posted by Old New Rider
I've got my 2021 Heritage...Stock shock is 'ok'...wonder if maybe going to a slightly longer shock...
It's a valid location, but there are other threads you will find more interesting. For the Heritage isn't the corner carver choice, usually.
Anyhow, do a search on @FranBunnyFFXII and see where she's made some posts on shocks and such, then go read that thread and the area she's posted in. By no means is she the only one who rides hard and can address directly what you're asking. But she's very down to earth and clearly spoken.
Old Jul 27, 2024 | 06:05 PM
  #3510
jspringator's Avatar
jspringator
I have the longer Fox shock. I like the shock, and I am happy with it, but it is very difficult to adjust the pre-load. I left it about 3/4 of the way up and it rides very well two up and solo. I understand Wilbers has a great shock for the Heritage, but it is pricey.
