2018+ Softail Models Breakout
The Everything 2018+ Heritage Thread
Old Sep 14, 2020 | 10:04 PM
  #2501
Hulkss's Avatar
Hulkss
Originally Posted by P51Driver
I have been using my J&S lift on my 2018 Lowrider and it barely fits underneath the bike. I see the Heritage sits a little lower than the Lowrider. My question has anybody used a J&S lift with a 2018+ Heritage? If so how did it fit underneath the bike?
The Heritage does not sit lower than a Lowrider.
Old Sep 14, 2020 | 10:23 PM
  #2502
P51Driver's Avatar
P51Driver
That's what I thought. But if you look at the specs the Lowrider shows a ground clearance of 5.1 inches. The Heritage shows a ground clearance of 4.7 inches. I think because that Heritage has smaller diameter wheels and tires it sets lower. But I hope I am incorrect and you are correct.
Old Sep 14, 2020 | 11:04 PM
  #2503
Hulkss's Avatar
Hulkss
I was only thinking of the longer rear shock on the Heritage which more than makes up for the tire difference in the rear where the suspension geometry is the same. The lowrider may be taller in the front depending on the forks.
Old Sep 15, 2020 | 06:45 AM
  #2504
tmac00333's Avatar
tmac00333
I have the J&S and it fits under my 2020 Heritage with no problem.
Old Sep 15, 2020 | 09:47 AM
  #2505
Morish's Avatar
Morish
Hello
I have J&S jack and I have used it on my 2019 Heritage.
The bike kick stand is mounted differently on my 2019 than my previous 2014.
The placement of the kick stand sets back I would say about 4/5 inches towards the back of the bike .
My J&S lift does come in contact with the kick stand. It touches the cross bar between the wheels of the jack. Prior, my 2014, the jack would be beside the stand with no issue.
The bike is secure when lifted up. Make sure as you probably know, be on a flat surface .
I hope this helps.
Old Sep 16, 2020 | 09:17 AM
  #2506
Uncle G.'s Avatar
Uncle G.
I notice the sidestand location interferes with my lift as well. Just one more thing I hate about the new sidestand design. That's what happens when you let the new hire design your motorcycle.
Old Sep 16, 2020 | 07:12 PM
  #2507
P51Driver's Avatar
P51Driver
Hulkss was correct. My J&S fits under my Heritage better than it did under my Lowrider.
Old Sep 16, 2020 | 07:16 PM
  #2508
Morish's Avatar
Morish
Mr. HULKSS is EXTREMELY knowledgeable. Thanks to his post re his Heritage, it has help me immensely finding custom parts for my new Heritage 114.
Old Sep 17, 2020 | 07:26 AM
  #2509
Rendezvous's Avatar
Rendezvous
Installed Hammock seat and Kuryakyn Floor Board Extenders. The added benefit of these two to riding comfort is amazing. Highly recommend 👍🏼
Old Sep 18, 2020 | 10:50 AM
  #2510
RoxSy's Avatar
RoxSy
What is this handlebar bag that you have ?
Seems interesting for long rides purposes.
