2018+ Softail Models Breakout
Swapping footpegs
Old Apr 30, 2019 | 07:24 AM
MadMouser's Avatar
MadMouser
Default Swapping footpegs
I've got my Kuryakyn Switchblade pegs from the Fat Bob that I want to put on the Sport Glide. I've also picked up the DK Customs adapters. And now I'm stuck in an "I'm overthinking this" loop and really need some help breaking me out of it. How are y'all working with those e-clips? I've found a few sets of e-clip tools, but don't know if the clips are reusable. So, anyone who's swapped out your pegs on these bikes, what'd you do to take off and put on those clips?
Old Apr 30, 2019 | 08:55 AM
Las Vegas Jim's Avatar
Las Vegas Jim
I just went through this exercise, and I also almost drove myself nuts; but I survived. Here are my lessons learned.
1. Most affordable e-clip tools are pieces of garbage and the points on the end of them are too big for a HD e-clip. You will definitely need a set of e-clip tools, but make sure the set you order has tools with an .038 tip. The set I finally found was on Amazon.
2. Yes, the e-clips can be reused, but they will never be as tight as a new e-clip. I bought a small bag of them at the HD dealer parts department for less than $1.
3. Until you are certain you will like the different pegs, use the old e-clips you took off the original pegs. They will be easier to remove the second time if you decide you don't like the different pegs. If you do like the different pegs, you can then remove the original e-clips and replace them with tighter new clips.
4. Depending on the size and thickness of the different pegs, you may find that the brake and/or shifter pegs are a different height and/or more forward/backward from the original peg and will have to be adjusted to match up well with the new pegs.
Overall, I found the exercise a little frustrating, but it was definitely worth the effort. The price of the tools and the replacement e-pegs was a lot less money than paying a mechanic to do the job. Plus, I now know how to work with e-clips.
Old May 1, 2019 | 06:10 AM
MadMouser's Avatar
MadMouser
Thank you, Sir!
You don't, by any chance, remember the ASIN or name of that set of tools you bought?
Old May 1, 2019 | 12:08 PM
Daedalus1066's Avatar
Daedalus1066
Originally Posted by MadMouser
Thank you, Sir!
When I did mine this is the tool I bought and used.
https://www.amazon.com/gp/product/B000JNRR0Y/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B000JNRR0Y/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
Irwin Snap Ring Pliers
It was not expensive it did not deform the e-clip and I have over a 1000 miles since replacing my pegs to Mini-floor boards with no issues.
Old May 4, 2019 | 06:47 PM
ole_phart's Avatar
ole_phart
Got this from Amazon and worked fine when putting forward controls on my FXLR:
E-Clip Tool E-Clip Tool
Old May 5, 2019 | 07:32 AM
MadMouser's Avatar
MadMouser
E-Clip Tool
Thanks! That's the one I ordered. I'll be here Monday, so I guess I'll be finding out how the old pegs do on the new bike.
Old May 5, 2019 | 11:19 AM
ole_phart's Avatar
ole_phart
Cool. I used the smallest one to get 'em off and the one labelled 8MM is a perfect fit to get 'em back on.
Old May 6, 2019 | 08:13 PM
Las Vegas Jim
They are OTC Signature Series Snap Ring pliers. Check the OTC web site otctools.com. The part # on the package is 4514.
Hdbkstl
Feb 1, 2019 03:45 PM
Cam6286
Nov 21, 2017 03:06 PM
zworld
May 18, 2012 04:41 PM
catken
Sep 28, 2008 01:10 PM
DeputyMike
Apr 28, 2008 06:18 PM
