2018+ Softail Models Breakout
Installed riser extensions on my Fat Bob
Old May 4, 2019 | 10:06 AM
FLS103's Avatar
FLS103
Originally Posted by FatBob2018
At $300 or less I would be in too. $600 is just way too much, I could get the TTS100 cam and a Dyno time for $600.
Going to do a CR-480 cam in the future but it's not a necessity. Had to raise the bars to ride comfortably, obviously you guys are younger than me, shorter than me or do not mind riding crouched over frontwards lol.
For me raising the bars was a necessity, The only things I did not like about the bike we're the ricer exhaust, the ergonomics (raising bars took care of that) and the cheap cheesy license plate holder. Those were the first things I took care of. Raising the bars was a necessity, got to be comfy to ride.
Old May 4, 2019 | 04:27 PM
FLS103's Avatar
FLS103
Just an update in case anyone happens to read this thread while searching for riser extensions.
I put some miles on the bike today between rain showers, maybe 10 miles in town, 15 interstate and 50 on back roads. The view in the mirrors is 100% better, I do not see the need for new mirrors now. The bars feel just as sturdy as before the riser extensions were installed. I just reused the stock bushings as they were still new (600 miles on bike).
These were expensive but they offered a quick easy install using the stock bars, wires, cables. The extensions are slightly over 3", I do not feel you could go any higher without a longer upper brake cable, longer clutch cable and wire extensions.
The aftermarket may offer more affordable options in the future for our Fat Bobs, but for now I am riding comfortable.
Hopefully those of you who are interested in raising your bars can find an option that suites you or maybe talk Rich into a group buy at a reduced rate.
Old May 5, 2019 | 12:25 AM
Bowhunter8607's Avatar
Bowhunter8607
So the shop I inquired with about making these said they can do it but feel the initial cost to make them would be too much to make it worth it so no dice there. They do look great and I totally like the simplicity of adding them but as other have said 600 is just too steep for spacers. Swapping the risers along with new bars, brake and clutch uppers and wire extensions will still be about 200 bucks cheaper for me so that's the route I'll go.
Thank you for the report after riding with them. And I totally get the necessity of raising the bars for comfort and I'm pretty short. Even though it is still a must and has been the next mod on my list before I do anything else. Thanks again and enjoy.
Originally Posted by Mchad
They do look very good. Looking at that triple tree, it looks like you can’t use regular T-bars or risers, is that right?
No you can still do T-bars and regular risers on the Fat Bob. The fat square risers just look good and flow better in my opinion but the regular round risers I've seen don't look bad either. Will probably do the same as Decker72 did here.
https://www.hdforums.com/forum/softa...fb-thread.html
Old May 5, 2019 | 08:45 AM
FLS103's Avatar
FLS103
I saw Decker's thread while doing my research and almost went that route using a different bar / riser combo. The bars and riser I wanted made the total investment basically the same cost as just the spacers with much more time involved.
So many ways to make these bikes our own. Gonna be watching your mods in future post. Your the reason I went with the Super Street exhaust.
Old May 5, 2019 | 10:21 AM
Bowhunter8607
After calculating everything again I'll come in at about 130 less for the entire set up. I guess it's about the same cost overall just get a lot more and have to do a lot more to install them. Forbidden Machine has risers that look almost identical to the ones Decker used for almost a quarter off the price so I may use those instead but haven't decided. I just like the look of those risers and the fact that they are drilled for internal wiring. Many others I've liked aren't set up for internal wiring.
I guess it's just a matter of deciding if I want to go a bit higher with the 9" risers and have to do more work, which isn't a big deal, or save some time and effort and get the extensions and go a couple of inches lower. I guess I have some contemplating to do.
Old May 9, 2019 | 03:33 PM
adm's Avatar
adm
Originally Posted by phunk
I run a CNC machine shop that focuses on auto parts. I am going to make some riser blocks. I just ordered a new stock riser from HD for $65 so I can use it for getting the dimensions I need without having to take my fat bob apart yet.
Do it man. 2 inches up and 1 inch back. Black powder coat to match the stock risers. Nice and beefy to match the stock risers.
$200 price point and you'll sell loads....
Old May 9, 2019 | 03:36 PM
phunk's Avatar
phunk
2 up 1 back is what guys on the fat bob group are suggesting to me also. Sounds good to me, I will try that out and see how I like it. Since I am usually backed up at work its possible I will only make 1 batch but who knows maybe it becomes a thing. But I am thinking that if I do 1" back that I might prefer to make a whole new riser rather than an extension block. I am afraid of how a 1 back extension would look with the stock riser, like a stair case. We will see.. when the stock riser set gets here I will put it all into CAD and see how it looks.
Old May 9, 2019 | 03:47 PM
Bowhunter8607
That's awesome. Wish I had access to someone like you. Haha. I think just a straight up 3" riser extension is perfect since the stock risers already have the pull back on them. Not sure why they would want 1" back on top of the already existing pullback on the stock risers. Unless you're just going to make a whole new riser.
Either way let us know how it goes and post some pics when you get them done. Like adm stated, if you make these and are able to sell them cheap you will probably make a killing. I would buy them for sure if they look anything like the ones FLS103 installed. Good luck.
Old May 9, 2019 | 04:39 PM
FLS103's Avatar
FLS103
Don't know why anyone would want the extension 1" back on top of the pullback already in the riser either. If you think about it, the + 3" extensions will bring the bars back closer because they follow the angle of the riser, they do not go straight up.
Look at the bottom of the stock riser, you will notice two small holes for the rubber bumpers. When you mill the extensions make sure to include the holes on bottom. The bumpers can be removed from the risers and installed on to the extensions, they need to be there to prevent vibration. Also, if you put the holes on top of the extensions as well they can be used for dowel pins. By pinning the extensions to the risers it will give more rigidity as opposed to being held together by only the riser bolts. It would also help align the spacers to the risers and keep them aligned.
I share this info because it is exactly how the pair I purchased are made.
Hope this works out for you guys, I had a hard time stomaching the price when I purchased these...good thing Bitcoin is up LMAO
Old May 9, 2019 | 04:52 PM
Bowhunter8607
Look at the bottom of the stock riser, you will notice two small holes for the rubber bumpers. When you mill the extensions make sure to include the holes on bottom. The bumpers can be removed from the risers and I stalled on to the extensions, they need to be there to prevent vibration. Also, if you put the holes on top of the extensions as well they can be used for dowel pins. By pinning the extensions to the risers it will give more rigidity as opposed to being held together by only the riser bolts. It would also help align the spacers to the risers and keep them aligned.
Good information to know. I wondered how they were keeping the risers and extensions aligned. Sounds like they were really thought out before just being made and slapped on. Makes me have a lot more faith in the extensions if I decide to swallow that horse pill and go with them.
