2018+ Softail Models Breakout
Installed riser extensions on my Fat Bob
Old May 9, 2019 | 05:23 PM
phunk's Avatar
phunk
Originally Posted by FLS103
Don't know why anyone would want the extension 1" back on top of the pullback already in the riser either. If you think about it, the + 3" extensions will bring the bars back closer because they follow the angle of the riser, they do not go straight up.
Look at the bottom of the stock riser, you will notice two small holes for the rubber bumpers. When you mill the extensions make sure to include the holes on bottom. The bumpers can be removed from the risers and installed on to the extensions, they need to be there to prevent vibration. Also, if you put the holes on top of the extensions as well they can be used for dowel pins. By pinning the extensions to the risers it will give more rigidity as opposed to being held together by only the riser bolts. It would also help align the spacers to the risers and keep them aligned.
I share this info because it is exactly how the pair I purchased are made.
Hope this works out for you guys, I had a hard time stomaching the price when I purchased these...good thing Bitcoin is up LMAO
I will make sure not to miss any fine details. I am all about that stuff.
Old May 24, 2019 | 03:02 PM
FLS103's Avatar
FLS103
Those look very good but not very tall. Maybe 1.5" ?
Old May 24, 2019 | 03:03 PM
izzyryder's Avatar
izzyryder
Awesome job.. that came out great!
Old May 24, 2019 | 03:15 PM
izzyryder's Avatar
izzyryder
Originally Posted by phunk
They have 1.25" of lift, very mild. Its just what I could fit in some scrap material I had laying around. I think this minor adjustment will be well and fine for my use as I barely wanted to change it anyway, I will see how it feels. In the meanwhile, I ordered material to make them in some longer sizes to try out also. The tooling that I had to make for producing these 1.25" blocks will accommodate up to probably 3" blocks if I wanted to go that far.
1.25” would be perfect for me. I sent you a PM. Any interest in selling a set?
Old May 24, 2019 | 03:21 PM
Dan D.'s Avatar
Dan D.
Put my name on the list also.
Looks great.
Old May 24, 2019 | 04:36 PM
Mchad's Avatar
Mchad
There’s a company called “emachineshop.com” that will machine parts, one off, using commercial or their own (free) software. May be worth looking at for one off builds...
Old May 24, 2019 | 04:55 PM
Hey Man's Avatar
Hey Man
Man those are some big clunky chunks of metal. They look like miniature bridge abutments and I'm not sure I'd be comfortable with one bolt going up the middle to hold that sandwich together. But what the hell. Motorcycles are supposed to be dangerous, right?
Now these are some beautifully elegant risers.
Old May 24, 2019 | 05:18 PM
FLS103's Avatar
FLS103
Beautifully elegant risers that have only one bolt and a small contact area on the tree LMAO. My big chunky ones have the bolt plus two dowels per side. If I had wanted beautiful and elegant I would be riding a Liberace bike (That's what we used to call a fancy bike back in the day). Didn't want a fancy bike so I got this big ugly Fat Bob to ride. But to each their own ✌️
phunk's Avatar
phunk
There is certainly nothing wrong with being cautious and curious when it comes to ones safety. But you are not going to make those riser extensions fail. The assembly is most likely far more rigid than what you have posted as alternative, unless those are a hardened steel. The footprint on the aluminum extension is at least 3 times larger, and the bolt passing through the middle is large enough that you can likely hang the entire bike in the air from just 1 of them.
Old May 24, 2019 | 05:33 PM
FLS103's Avatar
FLS103
Agreed, the extensions are billet and the bolts are grade 8. The large footprint is super stable, absolutely no movement whatsoever. I have had tall skinny risers and Tbars that were sloppy to the point of being scary.
